Throttle Body
4th Gear
Throttle Body
Hi all
I decided to clean my Throttle Body. I saw videos on how to clean it look very simple. Removing and installing easy. But when I turn on the car all hell went wrong with the car. Engine (P0507) and VTM lights on, RPMs high. when I turn on the car the RPM are going up and down. Has this happen to anyone? Took the car to Acura and was told the car needs a new Throttle Body Total Cost $998.00
Before taking the car in any subjection.
Thank you
2005 Acura MDX 92,000 Miles
Thank you
You more than likely disconnected and forgot to reconnect a vacuum line to the throttle body. If not that, then there is a leak after the throttle body, did you make sure the gaskets lined up properly and everything was torqued properly?
Yeah id def chk to be sure you plugged back in all the connectors and vacuum hoses. Sometimes they can be missed. I would also def not even consider 1k for a TB...
Let us know what ends up happening
here is a used one i found for ya from car-part.com if u end up needing one...
2004
Throttle Body
Acura MDX3.5 V6 C80323$75Rockford Auto Parts USA-IL(Rockford) Request_Quote 1-815-964-3396 Request_Insurance_Quote
2004
Throttle Body
4th Gear
Hey whats up
Today I brought a use Throttle body. I installed it and still not working. With notting to lose I change the censer. That did it all engine light turn off RPM’s are back to normal
Thank you all
Thank you all
2003 Acura MDX
while we are on the topic, i have seen a wider (?) throttle body available for the MDX (2003). If i did buy it and had it installed, would the difference be significant? what are the consequences of getting a wider one?
thanks in advance.
thanks in advance.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
