Question to Gurus.
Old May 22, 2016 | 09:32 PM
Skirmich's Avatar
Question to Gurus.
Sup!
I am trying to find out the ATF flow in my 2G MDX.. Just need confirmation from you guys.
As far as I have been reading the Service Manual it is:
Trans > Radiator > ATF Cooler > Trans
Is this correct?
I am trying to by pass my radiator cooler (To prevent future damage on a failing radiator ATF cooler) but I don´t know if the OEM ATF Cooler has a built in T-Stat or not? Pictures are very vague but it seems like is a straight through cooler. I want to by pass the radiator and Install a big ass ATF cooler instead but I don´t want it before the OEM ATF Cooler if it has a built in T-Stat..
I would like to know either of that.
1.- Is the flow diagram correct?
2.- OEM ATF Cooler has a built in T-Stat?
Either of those answers will work for me.
If it has a T-STAT:
Trans > OEM Cooler > AFT Cooler > Trans
If it doesn´t have a T-STAT:
Trans > AFT Cooler > OEM Cooler > Trans
Old May 23, 2016 | 04:04 PM
Skirmich's Avatar
No one?
Old May 23, 2016 | 04:16 PM
Shooting in the dark but check to see if there's any codes for ATF Temp Sensor circuits, that would sort of be the way to figuring out if the ATF system has a thermostat.
or look at the parts list online?
Old May 23, 2016 | 05:54 PM
Carpayment4life's Avatar
Over cooling the fluid will cause bubbles/foam.
Choose a low pressure mid size, for a V6.
You'll see that large trucks have very large BTU options, you won't want one that big.
Some low pressure coolers are directional and I don't know if the OEM cooler is marked in/out.
To determine the direction of flow, remove the hose from one end of the OEM cooler and have some quickly start and stop the engine. The fluid will either squirt out of the hose or out of the cooler.
Old May 23, 2016 | 07:52 PM
Skirmich's Avatar
Thanks for the inputs
This is the OEM ATF Cooler:
It looks like a straight through to me..
I think I am going for V8 Car ATF Cooler.. Considering the GVWR of the MDX and our 120°F summers seems like a right fit as the OEM ATF Cooler looks like an afterthought.
This is what I am going for.. Medium Sized B&M ATF Cooler: B&M Oil Cooler, Medium Supercooler 13,000 BTU Rating, Black » B&M
Old May 23, 2016 | 07:56 PM
Skirmich's Avatar
This is the real size for reference (taken from a pilot)
Old May 23, 2016 | 07:57 PM
Skirmich's Avatar
If ATF gets too cold I will use the OEM ATF Cooler as a Power Steering Cooler and leave the B&M as an Exclusive cooler for the ATF.
Old May 24, 2016 | 08:53 PM
nats007's Avatar
Interesting... I personally don't know, but I figured if this was done on the Honda Pilot, it can't be too far off for the MDX
Old May 24, 2016 | 09:26 PM
Skirmich's Avatar
It isn´t overkill in my opinion.. We don´t have freezing temps here in So Cali and our summer are scorching hot 125°F.. This solution helps both ends, Piece of mind for the radiator cooler failure and 125°F summer protection.
Old May 25, 2016 | 08:43 PM
nats007's Avatar
You're not shy to DIY lol! Give us a write up when you do it Sir
Old May 25, 2016 | 10:00 PM
Skirmich's Avatar
I think I have over 10 Written DIYs here in Acurazine.
I will try to do this as a DIY too but its so straight forward it might just be useless.
travr6
Jul 22, 2018 03:21 PM
waxy1926
Apr 25, 2016 07:21 PM
Ziplok
Apr 3, 2016 06:59 PM
bsprinker
Jan 31, 2016 02:16 PM
Powder Monkey
Jan 14, 2016 11:18 AM
