need help with starting the car!
Old Oct 11, 2010 | 08:30 AM
GatorsMDX's Avatar
5th Gear
Hello all,
My 2007 MDX went dead over the weekend, i tried jump starting the car but it wont turn the car on, but the navigation screen came up and asked me for a code. but i do not know my code! I'm wondering if this is the reason why the car will not turn on. I am going to try to charge the battery using a battery charger, in the mean time, all comments are appreciated!
thanks in advance!
Old Oct 11, 2010 | 01:59 PM
Peregrine99's Avatar
Anything code related would be in/on the owners manual card. If that doesnt work, call the dealer
Old Oct 11, 2010 | 02:03 PM
Ken1997TL's Avatar
Your MDX has enough battery power to run the navigation system but not enough to crank the engine which requires a LOT of power in a short amount of time in comparison.
Your navigation code is four digits and should be included in any documentation you got with the vehicle. It MIGHT also be on the inside part of the lid of your fusebox (the one in the engine bay) At least, thats where the codes are on my two Acuras.
Old Oct 11, 2010 | 02:09 PM
or the starter is toast
Old Oct 12, 2010 | 02:48 PM
black label's Avatar
Trolling Canuckistan
Like Ken said, the nav code has nothing to do with startng the car. You nav code (and radio code) would be on a card that theoretically should be with your owners manuals. If you do not have that card, check the lid of the engine bay fuse box for a sticker with the code printed on it. Some dealers put a sticker in the glove box instead of the fuse box, you should check there as well. This code also should have been noted in your "maintenance journal" which should be in with your owners manuals as well.
Old Oct 25, 2010 | 09:25 AM
GatorsMDX's Avatar
5th Gear
well, finally got the car started after charging the battery for about 24 hours. now i just got to find the s/n for both radio and navigation to get the code since my dealer did not put the code when i bought it as CPO...
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
