Mirrors dipping when Backup
Old Mar 31, 2012 | 06:37 PM
cadfael_tex's Avatar
IIRC the mirrors on my wife's '07 MDX used to dip when we put it in reverse. They don't do that anymore. Is there something I'm missing - a setting or something? Or are they just broke?
TIA,
Tony
Old Mar 31, 2012 | 06:46 PM
ZhenyaF's Avatar
Off roading in his
The mirror adjustment should be pointed to either the right or the left for them it dip, instead of being in the middle
Old Mar 31, 2012 | 09:32 PM
grappletech's Avatar
Yup, what he said^ If not on my Tl there was a blown fuse cause by frozen water in the windshield washer spray. But try the mirror adjustment first
Old Apr 27, 2012 | 07:37 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
On my TL there is a setting that can be played with according to user settings and which memory key is used. Try that...
Old May 3, 2012 | 07:39 PM
BlacknWhite23's Avatar
On our '01 it has to be in the middle for it to work, not on the right or left. Then it tilts down.
Maybe on the newer ones it is different.
Mike
Old May 5, 2012 | 11:47 AM
Newplay1's Avatar
08 MDX with Sports
Oh that's why my passenger mirror started dipping LOL.
Old May 6, 2012 | 10:42 AM
woofster's Avatar
8th Gear
Mike
Same with our 2003. One day my wife adjusted one of the mirrors and forgot to put the switch back to the middle position and the passenger side mirror didn't tilt downwards. Caught me off guard but I noticed the little switch right away. I find it's a good method to turn the mirror tilting feature off.
Old May 20, 2012 | 06:41 PM
lisrangar's Avatar
Everyone is right. First generation: switch in the middle, passenger side dips. Second generation switch on left, drivers side dips, right, passenger side. Center for off.
Old May 21, 2012 | 06:42 AM
db22's Avatar
I guess this is why they supply a manual with each car that pertains to the car of that model year?
Old Jun 30, 2012 | 12:15 AM
kmscrap's Avatar
So you're saying you can choose which mirror you want to dip ? If that's so then great. I thought it was odd if only the passenger did, because if I'm parallel parking on the left side of the street, the right mirror dipping is of no use. I will move the lever.
Thanks,
Kristin
Old Jun 30, 2012 | 01:32 AM
rondog's Avatar
Former Sponsor
My 08 dips, but when I go back to drive, it stays down. I have to manually get it into the right position.
Old Jul 29, 2012 | 12:43 AM
kmscrap's Avatar
On my '03, the passenger side only dips, so I would always have to parallel park on the right side of the street.
Kristin
Old Jul 29, 2012 | 10:57 AM
wrestrepo's Avatar
StayAtHomeDad
That's wrong, something must be broken.
Old Aug 13, 2012 | 12:41 AM
sigp228's Avatar
SYMPTOM
Either or both of the door mirrors have one or more of
these symptoms:
• After shifting out of R, the power mirror does not
return to its normal position
Take to the dealer and have them perform TSB 09-047
Acura604
2G RDX Photograph Gallery
27
Oct 8, 2020 09:24 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
