Ignition key stuck
Old Mar 1, 2009 | 07:07 AM
Jose Espino's Avatar
Ignition key stuck
The ignition key in my 2005 MDX is stuck. I can't get it past the ACC position unless I disconnect the battery. I have just over 80K miles on it and this is the first time I've had any problem with the vehicle. The only recent change that may be of consequence is that I recently purchased a Garmin GPS unit and left it plugged into the cigarette lighter power adaptor. It acts like the vehicle is left in gear when I try to turn off the car off and remove the key. I'm hoping this is a fuse or relay problem, but I can't seem to locate a related item in the owners manual. Anybody have any ideas where to look?
Old Apr 21, 2009 | 05:09 PM
jacecesar's Avatar
8th Gear
I think you need to check the dealer because maybe the relay of your shiftting gear is connected to the ignition .
Old Apr 21, 2009 | 05:10 PM
jacecesar's Avatar
8th Gear
maybe the relay is grounded, sometimes its open and sometimes is closed .mayba need to replace
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
LoneRonin
Sep 28, 2015 09:11 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
