Check Transmission D Blinks
Seems that there is an issue with the Solenoid C in the Trans..
How is the fluid looking? any records of maintenance?
Check the ATF Level otherwise this will be a Dealership only Part...
You can either try to clean the solenoid or it is malfunctioning which will mean you have to replace it.
If you go to a private shop try to go to a Transmission Shop, Not a general Mechanic.
Thank you so much for all the information.
Since I am worried to drive a long distance will try once with my nearby Gas Station mechanic first and see if I can get a quote first.
Most of the solutions given on the web goes behind changing the Transmission Fluid will try that first.
If i can drive to the Dealer then will check it out at the Acura Dealer too.
P1717 = TRS needs replacement check my thread in this forum: https://www.mdxers.org/forums/74-sec...ty-switch.html
