Check charging system flashing
Old Feb 3, 2019 | 03:52 PM
nats007's Avatar
Good afternoon all,
So unfortunate turn of events this weekend. MDX died on the Mrs while we were on out of town. I ended up getting a new battery and a new alternator from AutoZone that was remanufactured (only one available) to get back home.
Spent the next 6 hours installing it with my dad and it was a PITA. All seemed well until this morning. As I started driving, the check charging system light would flash during braking. I went back to Autozone to return the core and test out the system. Both battery and alternator tested good/pass. With that, I was able to make the 3 hour drive home, but still have this check charging system light flashing.
Any tips?
Old Feb 3, 2019 | 06:02 PM
Originally Posted by nats007
Good afternoon all,
Any tips?
Bad tension on belt
Old Feb 3, 2019 | 07:01 PM
nats007's Avatar
Bad tension on belt
I read the belt tension could be an issue. The belt Im running only has about 6k om it (changed with last service). It was very tight to get off and on, so I don't think it's tension. I ended up checking all fuses and they seem to be ok. Just completed an oil change and reset the Maintenance minder, so we'll see if there were any improvements.
Old Feb 4, 2019 | 07:04 PM
nats007's Avatar
So, I cleared all codes yesterday and thought all is well. Left work this evening and the check charging system was flashing again intermittently. I called my Indy mechanic and explained the issue and he bet it's the refurbished AutoZone alternator. Bringing it in tomorrow to test and then swap for a Denso/OEM equivalent alternator.
Old Sep 4, 2020 | 11:28 AM
tltoledo's Avatar
Hi nats007,
What ended up being the problem?
I am having the same issue, it died. changed alternator, battery, and even a relay. "Check Charging System" still flashes a lot.
Old Sep 4, 2020 | 11:48 AM
Originally Posted by tltoledo
Hi nats007,
Bad tension on belt
did you check tension on the belt/ replace the tensioner or the belt itself?
Old Sep 5, 2020 | 01:12 PM
tltoledo's Avatar
Can you elaborate a bit?
Which belt? Serpentine?
Old Sep 5, 2020 | 01:15 PM
yes, other wise known as the accessory belt...it drives the accessories...the accessory belt loops or wraps around the alternator.
or like the original poster found out, it may have been a faulty alternator.
Old Sep 8, 2020 | 07:49 PM
nats007's Avatar
Hi nats007,
Issue was the remanufactured alternator. I replaced with a new OEM Denso, returned the remanufactured alternator, and no issues since.
For these vehicles, I'd stay away from remanufactured alternators if possible.
Old Sep 11, 2020 | 07:49 PM
acuratech481's Avatar
Stay away from aftermarket alternators. Honda factory reman parts are totally fine.
schen72
Nov 7, 2020 06:14 PM
mrclemson
4G TL Problems & Fixes
Aug 21, 2020 01:41 AM
ewilliams2012
Mar 28, 2020 01:29 PM
john6699
Dec 19, 2017 01:31 PM
supreme710
Feb 22, 2017 03:38 PM
