19x8.5 45 ET or 40ET or 35ET or 20ET??
Old 11-30-2015, 08:36 PM
novasteve's Avatar
Talking 19x8.5 45 ET or 40ET or 35ET or 20ET??
Pretty sure I am going to go with these wheels. They are offered in all of these offsets. Which would require the least mods? They are concave style wheels and also wondering which would be the most concave with all things being equal?
I do plan on going with Tein coilovers as well.
2012 Wagon is the car.
Thanks for any help!!
Old 12-01-2015, 10:14 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
Go with the +35. They fit, and will sit a bit more flush than the +45. +20 will not work without either fender work and/or thinner tires.
novasteve (12-08-2015)
Old 12-01-2015, 01:37 PM
novasteve's Avatar
Thanks, I appreciate response!
Old 12-01-2015, 10:48 PM
novasteve's Avatar
i plan on doing 235 35 19. Would prefer to do 40, any thoughts?
Will +45 work? Probably need spacers to make flush, correct?
Old 12-01-2015, 10:52 PM
BROlando's Avatar
Received 1,166 Likes on 877 Posts
45 is pretty weak with a 8.5 width. Unless you want to run factory camber out back?
I have +38's with 245/40/18. Natural camber (like -2.5), and they just clear the stock front and rear lips.
Front natural camber is like -0.5 or so.
Old 12-01-2015, 11:33 PM
novasteve's Avatar
What do you mean 'weak'? Not aggressive looking?
I have no problem doing a camber kit as well. I plan on lowering 1.5"-2".
Would like to keep the ride quality good and not go too low.
Old 12-02-2015, 07:31 AM
BROlando's Avatar
The higher the offset, the less agressive the wheel fitment. Meaning that the outboard face of the wheel sits inboard of the fender wall.
*IF* you are buying a camber kit to return to stock settings, and you want to leave your fenders 100% stock, then the +45 will work.
I have 8.5" wide wheels with a +38 offset, and 245/40 tires.
I am also lowered 1.5-2".
My camber ended up around -0.5 front and -2.5 rear.
I did not buy a camber kit. If I adjust my rear camber positive at all...I will have to roll my fender lips so that the tires don't rub on it.
Old 12-05-2015, 06:43 PM
6th Gear
brandonK24's Avatar
Hey man do you know if 19x9.5 +35 will work? Im not lowered as yet. I wanted to do 19x9.5 +45 all around. tires 245/35/19
Old 12-06-2015, 08:39 PM
BROlando's Avatar
Not without fender modification. It will also look awful at stock height.
Old 12-07-2015, 08:29 AM
xtcnrice's Avatar
9.5 +45 worked for me on 235/40r18. 245s? I can't guarantee no rub on the fronts. But 9.5 +35 will rub with those specs for sure. You'll need something less comfy like 225/35r19 for that to work, but like Roland said, it won't look good at stock height.
Good luck.
Old 12-08-2015, 08:11 PM
Dude
dave_88's Avatar
get 245/35/19 or a 40 series.
source: i have 245/35/19
Old 12-08-2015, 10:09 PM
novasteve's Avatar
Any pics? Are you lowered? Will a 40 series fit without rubbing?
Old 12-09-2015, 11:33 AM
BROlando's Avatar
40 series? What width? If you're talking about 245mm width, then 245/40 will be quite a bit taller than a 245/35 (almost 1" taller). They will both be the same width. The width is usually what makes things rub.
The second set of numbers (40, for example) is based on the first set.
245/40 = 245mm wide. 40% of 245mm per sidewall. About 196mm total.
235/35 has 171mm total sidewall.
They're not even close to being a "you can use either" size.
245/40/19 is about 1" taller in diameter than the stock 225/50/17.
xtcnrice (12-09-2015)
Old 12-09-2015, 05:24 PM
novasteve's Avatar
I'm talking about the sidewall. Thinking 235/40/19.
Old 12-09-2015, 06:26 PM
PROFESSIONAL IDIOT
V-tecAc's Avatar
If your a man run 9.5 with a 35 profile tire haha
Old 12-09-2015, 09:14 PM
BROlando's Avatar
Originally Posted by v-tecac
if your a man run 9.5 with a 35 profile tire haha
wat?
Old 12-12-2015, 07:30 PM
Op is too busy to care
KillerG's Avatar
There is a suspension megathread go there and look at the cars and copy someones wheel specs. Simple as fuck.
Old 12-16-2015, 02:25 PM
novasteve's Avatar
Yeah, didn't see anybody running the exact specs I'm thinking of. So, not 'simple as fuck'
Old 12-23-2015, 11:17 PM
Dude
dave_88's Avatar
i posted my car in the wheel set up thread. i don't rub at all but i'm not super dumped on coilovers - just pretty low it gives me just enough problems - since i actually drive my car through the crappy streets of philly.
when i ordered my tires, tirerack actually called me and tried to get me to get a 245/40/19 size instead, but i told them no since it was too tall.
Old 12-30-2015, 11:20 PM
KillerG's Avatar
Mmm... No its genuinely simple. This is a 5 year old+ forum and all of the resources for basic wheel fitment are numerous and plenty. There is an entire subforum hosting years of similar posts and a compiled thread to make it even easier
But you know what youre right you might be the first person to ever run 19x8.5. Should be sick.
Evinac
12-16-2015 01:26 PM
SergeiG
11-30-2015 11:00 PM
SergeiG
11-30-2015 09:04 PM
LaJay007
11-30-2015 08:23 PM
s2000gtx
11-30-2015 01:40 PM
Quick Reply: 19x8.5 45 ET or 40ET or 35ET or 20ET??
