A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
#1441
Wondering if the 10mm will help with the TB cover bolts? I think I'm going to go ahead and snag both the inch and metric sets at this price ($50 each). Why the F didn't they include a 12mm in the metric set?
Sears.com
Sears.com
#1442
I actually didn't have a problem with the 1/4" ratchet and socket iirc...I think i loosen, then just hold the socket itself in my fingers to remove. A lot of those ratcheting wrenches seem to offer too much play and have weird angles and I end up not using mine.
#1443
Thanks for this great timing belt tutorial.
I have just succesfully finished my 08 Base TL with 150,000 miles that I purchased back in 2009.
The parts I removed all looked like they could go to 200,000 miles easily.
The job is a hard one and you can get into trouble easily if you are not very careful. I cross threaded one screw hole and it was a pain to fix. Also I found that if you get the belt spacing correct between the camshaft pulleys, and you have the slack down to the tensioner, that you can get a one tooth 'bubble' error on the back of the rear camshaft pulley. This makes it very hard to get the timing belt over the tensioner, but if not corrected will throw off your timing if the engine is rotated. I wonder if others have had this problem.
I could not have done this without my harbor freight square drive socket caps (67011) and rachet wreches. Also a 7/8" socket fits well over the radiator drain vavle to loosen it. I removed the shock tower cross bar for room. And the battery hold down bolt is easy to mushroom and hard to remove if you do, so I would recommend adding the nut to the end of the battery hold down bolt after you thread it through the boss on the engine.
#1444
I had that same issue with the rear tooth, but I had marked the belt and the cam with silver sharpee so I knew I was off...plus, I knew where the slack should be thanks to Majofo. That said, I used a ratchet to bring the rear cam back one to fit belt then pulled it taut.
Glad it all worked out for you!
#1445
#1446
rockstar143 (05-07-2015)
#1448
Anyone know anything about this alternate style tensioner? Bundy claims it's less prone to failure/leakage... (8:30 in the video). Part # is: 14520-P8A-A01
#1449
oil seals suck
I had everything ready to go, but then i started reading about having the oil pump resealed. Is there a kit with all the oil pump related seals?
Must i order them individually ?
I have been searching and so far tracked down two which im going to order if i cant find the kit
#3 & #11 from the link below (any others to worry about ?)
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
Reason i ask, Majofo's first picture you can see the seals over a fel-pro box.
All i could come across it this Crank seal kit which may be just what he ordered along with the seals http://www.rockauto.com/catalog/more...nid=426&jpid=2
#1451
Why are you replacing the seals? ....and IIRC, Majofo never used those seals....
#1452
I think you are referring to VTEC solenoid behind the oil pump. Mine on my Accord V6 is leaking at 200000 miles and I will be replacing it at the next oil change.
#1453
Originally, wasn't going to bother with the seals. But since everything is going to be apart why not. Some people have oil seal issues with it others don't , rather have the "piece in mind"
Ended up ordering them just in case i do decided to pull the oil pump apart.
#1454
just bought a type s
Just bout a type s 07 blue and it has 163,000 on the dash don't know if the original owner changed timing belt or water pump do u guys think I should change . The dealer is charging me 1200 to do it but the kit is only 350 wit ship and handling.
erg69 (06-03-2015)
#1457
Tell tale stuff is if the timing covers / crank pull bolt have any scuffs on them. If not, then probably wasn't changed. Next, take the covers off and check the belt, water pump, idler pulley and auto tensioner for wear (check the DIY for pic comparison).
#1458
Newbie to the site
2006 TL with 103K miles
2007 MDX with 98K miles
Great write up and thread! Spent the last two days reading all 137 pages
This is on my to do list in the next couple of weeks on the TL. Have MM A14 service due.
I have done V6 TB on 2000 Passat (3 times) and 4 cyl TB on Mitsubishi Outlander (3 times). With these two cars the first time TB change went without any problems. They both recommend TB replacements at 60K miles.
On the Passat 20K miles later the water pump started leaking and 30K miles later the idler pulley came apart. The water pump was under warranty from online supplier but it was PITA to do it again. On the idler pulley it was out of warranty (2 yrs/24K miles) so I had to get another kit. I went with another online vendor.
On the Outlander they recommend every 60K miles, so after the second set the water pump started making noise. Autozone replaced it under warranty but also PITA to have to do it again before 60K.
The lesson I have learned is to use OEM parts moving forward! I would rather pay a little more money for parts and not have to do the install again before 100K miles.
Getting ready to order a kit from Amazon and oemacuraparts.com. Amazon kit does not include auto tensioner and thermostat.
I have a few questions.
1. Does the SM say anything about replacing the CP bolt?
2. Does the CP bolt need any thread locker?
3. On write up #11 picture shows to dab thread locker. Is this for every bolt for WP, idler pulley, adjuster and auto tensioner?
4. What color thread locker (red or blue)?
Thanks,
George
Thanks,
George
#1459
1- CP does NOT need to be replaced (Honda doesn't use torque-to-yeild-bolts).
2- CP bolt needs clean motor oil on the threads and between the bolt head & washer (gives most accurate torque)
3- Thread locker is only called out for use on the idler pulley toward the front of the engine (not the tensioner pulley)
4- I chicken out and use blue.
All the parts in the Gates-brand kit are OEM except the water pump. Therefore Buy the Gates kit without the water pump & tensioner. Then get the Aisin-brand hydraulic tensioner separately (it's OEM). The only part you need with a Honda logo on the bag is the water pump...and my post above has a brand new one for sale for cheap.
#1460
OEM Honda belts are stamped with the "Unitta" brand. That's the Gates brand in Asia. The Honda water pumps are Yamada brand, now called YNA (Yamada North America).
I would go with Gates TCK329. That kit will fit both your vehicles. My water pump will fit both your vehicles too:
For the tensioner, Aisin BTH001 is what you need for both cars.
Slpr04UA6 (06-06-2015)
#1463
My main concern is the parts for the TL (water pump, tensioner, idler,and bearings). My daughter drives it back and forth to college (Dallas to A&M) about 3 hour drive. My wife drives the MDX here is Dallas so not as important if something fails.
I have already ordered the Aisin kit THK-002. I will order the gates kit and tensioner next. I'll install all the OEM parts on the TL and the OEM like parts on the MDX.
#1464
92K on the Gates kit, no issues....
#1467
Yeah, I'm convinced that those Gates owners who got leaks screwed up the gasket and/or over-torqued the water pump bolts.....
#1468
Got all my parts in and getting ready to do this work.
One question on the gates kit it comes with a large washer shim. The Aisin kit did not come with a shim. Is it required? I didn't see anything about it in the write up.
Thanks,
George
Thanks,
George
#1470
Here's a video on the Service Bulletin 08-031 that was put out.
https://youtu.be/Tz-89-jrBOA
I was thinking of putting the provided shim on mine. It makes the same noise as the video.
The gates kit comes with a copy of TSB PA006-11. On the back it list of makes and models. For 2005-2008 TL V6 nothing is listed for vin. Now for MDX 2005-2008 V6 is list ALL?
Confused??
#1473
Was my timing belt changed?
Unboxing Gates Timing Belt J Series Honda Acura V6 Review - Bundys Garage - YouTube
Based on this, can I assume the belt is not the original and that it was changed by someone who installed the Gates kit?
There is no sticker on the strut tower or under the engine cover, etc., where mechanics often put this information.
Timbert (06-18-2015)
#1475
2005 TL with 119k and unknown service history. TB marked "OHC329 Made in Japan" and then "310184" and the rest of the numbers in sequence as in the video Unboxing Gates.
#1476
This brings up an interesting idea. I've seen VW's with the date/mileage marked on an external piece like a plastic cover. I think they use the same yellow paint marker's that the junkyard guys use to mark parts. Might be nice for the next owner.
#1477
Finished my install yesterday and it's running great. Thanks for the write up and tips.
It took me longer than I expected (13 hrs solo). I was taking my time and ran into a couple of problems.
Here are a few things that I had to deal with.
The CP bolt broke loose on first try. Set up jack stand, break bars and 4' pipe. When it broke loose I thought the socket or extensions had broke. Got everything off as described. My biggest problem was I thought I sent my crack on TDC with the covers on (per #5 on write up). After I removed CP and timing covers I noticed I was 180* off. I put my CP bolt on and turned it 180* and got marks lined up correctly. Big mistake I didn't put the crank pulley with the bolt. I got TB off and replaced when I was getting ready to put the TB on I realized that the CP bolt was not coming off. I had to take off the starter and put a wedge on the flywheel to lock and hold the crank to be able to removed the CP bolt.
During removal I noticed oil leaking at the bottom of the crank pulley. Not sure where it was coming from so I decided to replace the front crank seal. I used a tip that I got from VW when I changed the seal on my old passat. I drilled small holes on the seal and put in sheet rock screws. I put vise grips on each side and pulled it out. On the new one I put some grease and tapped it in slowly till it was flush. I have a pic that I will try to post.
When I was putting on the TB I was having trouble getting the rear cam to line up. It was slightly off. I tried to move the rear cam just a little forward to get it to line up and the cam sprung forward. Got it back in line and went with it slightly off.
During reinstalled I noticed step #13 should be after #14. Starting with side mount bracket on engine, timing covers, drive belt tensioner (without belt) and then step #13 (crank pulley and bolt).
One of the toughest was getting to the thermostat bolt on the back. This took me forever to find and loosen the bolt that holds the wire harness to get enough room to get to the back theromstat bolt. In my opinion this is not worth the effort and something you could skip from doing. The old thermostat looked better than the new one.
I left the spark plugs and oil change for the end. I wanted to make sure I didn't have any problems with the TB first. Started it up and everything was good. No codes or noises. Let it warm up and cool off.
Lastly I replaced the spark plugs, oil change and rotated the tires. When I started it back up I got check engine light with code P0306 (#6 misfire). During my last TB change on my bothers Outlander I invested on a basic code reader. This came in handy so I didn't have to go rent one. Problem was wire harness on #6 was not completely connected. Got it connected and erased code.
Running great.
A couple of notes. I went ahead and installed the shim behind the idler pulley provided with the gates kit. I was also confused which bolted needed thread locker (idler pulley or adjuster). I went ahead and put it on both. I should have came back and read my post from above on Q&A #3 answer by 94EG!
Once again thanks for write up and all the tips. It was worth reading all 37 pages!
Running great.
The following 2 users liked this post by ghernz:
rkpatt (07-15-2015),
rockstar143 (06-14-2015)
rkpatt (07-15-2015)
