reverse sensing wire
Old 12-18-2011, 08:38 PM
raydog318's Avatar
i need some help finding the reverse sensing wire for a 99 acura tl. trying to hook up a rear view camera. thanks
Old 12-18-2011, 09:44 PM
-Arsenic-
02type-s's Avatar
Get a light tester (cheap). It will take 5 mins
Old 12-18-2011, 10:42 PM
crownovercoke's Avatar
Your transmission range switch is on the transmission. The white wire is the reverse. It goes to a relay then to reverse lights. Not sure but I think taping anywhere between the relay and bulb should be enough to turn on camera.
Old 12-19-2011, 10:45 AM
thats correct
must be AFTER the relay--thats where power actually comes out from after fuse protection
grab the white wire anywhere from there to the back up bulbs- thats an easy place to access the wires,,the bulb~
12 volt test probe or multimeter for numerous elect tests is a smart buy for every toolbox
5 bucks at parts store, harbor freight gives $4 multi meter away all the time, ck coupons
congrats on investing in safety with a camera!
Old 12-19-2011, 03:05 PM
raydog318's Avatar
thanks!!!!!!!!!!!
Old 12-19-2011, 04:16 PM
sammy95's Avatar
Get a meter. It's better!
Can't tell 12volts with a test light.
Old 12-20-2011, 04:46 PM
TLer trash's Avatar
The wire color should be green/black. You probably have a trailer connector behind the carpet in the left rear quarter. The white wire is from fuse to switch, don't mess with it.
MrHeeltoe
20
02-23-2023 01:54 PM
SUPRMN84
10-07-2015 09:46 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: reverse sensing wire
