Sun Roof and keyless exit locking
Old 12-21-2009, 09:37 PM
mayflowerman's Avatar
Just got a used 05 RL. I noticed that the Sun Roof doesn't have an "auto" open or close feature. It seems difficult to know when it's properly closed. Any tips? Also, the manual says to push the button up (towards the sky, I assume and not forward or back) to tilt the sun roof. But nothing happens when I push up.
The keyless lock seems to not work when I exit the car. I grip the door handle and push the "bump" and it doesn't always work. Any suggestions?
Thanks in advance.
Old 12-22-2009, 06:18 AM
miner's Avatar
For the sunroof, if you push the button back PAST the first click-stop then it will open automatically. The same when closing except push the button fwd past the click-stop. There have been know issues with the door handles auto lock/inlock not working properly. To lock you do not need to grab the handle - just 'brush' the bump. To unlock you grab the handle. You might make sure your key fob is linked to the car.
Old 12-22-2009, 09:16 AM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Received 1,806 Likes on 793 Posts
From MyAcura.com:
Keyless Operation.....
http://owners.acura.com/Model/Featur...delid=KB1656KW
Features and Controls....
And of course, Colin's video is one of the best detailed....
http://video.google.com/videoplay?do...&hl=en&view=3#
Old 12-22-2009, 09:23 AM
Chas2's Avatar
I think you need to have the car relearn the sunroof open and close positions.
Search is your friend. Look at post #9
https://acurazine.com/forums/2g-rl-2005-2012-76/moonroof-has-lost-its-mind-2005-rl-498582/#post7498448
Actually, I think google often works better. Search using Google.
Go to google
type into the search term box
site://rl.acurazine.com [insert search terms]
such as
site://rl.acurazine.com moonroof reset
Old 12-22-2009, 12:13 PM
neuronbob's Avatar
Received 4,612 Likes on 2,193 Posts
Thanks, Chas.
Old 12-22-2009, 06:38 PM
037's Avatar
https://acurazine.com/forums/showthread.php?p=7498448
Go to google
such as
google is great but you also need to know the keywards which a new face on the forums would not.
great start though.
Old 12-22-2009, 10:59 PM
Thanks much for the wisdom. Seemed to work much easier on my 05 TL. Will follow up after I try the suggestions. Thanks again.
Old 12-22-2009, 11:24 PM
Hey!!!! That fixed the problem. Post #9 works!!! Thanks much. So did the tip on "brushing" the dimple on the handle to lock. Gripping it was causing the car to get confused as to if I opening or locking the car. Thanks again for the tips.
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
soupi
14
11-15-2015 11:15 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Sun Roof and keyless exit locking
