RL Calipers Fit behind 05 TL 17" rims!
#682
Gotcha! Didnt know fastbrakes was giving rotor recomendations
What pad and rotor combo you goin with?
Iv had ebc in the past. Slotted rotors and red stuff pads. Had issues with the rotors right off the bat. Never got past the break in periord for the setup.
Ultimatly they sent me replacements but that may have contributed to the bad taste in my mouth. Never ended up putting on
The following 2 users liked this post by Stephen00TL:
R J Poseidon 6 (03-24-2016),
teh CL (03-22-2016)
Stephen00TL (03-23-2016)
#687
Can i ask u a question/ small favor. Can you give me a measurement from your rotor face to the outside of the caliper!!??
Im trying to verify rim fitment without goin thru all the work only to find out i need spacers which i refuse to do. Not looking for opinion on spacers just not my flavor
So the rotor face to the ouside of the caliper. Maybe also from the rotor face to the backside/inside of the rim face?
So fastbrakes brzckets you had no issues huh?
Did you use spacers adapters anything of that sort or was it strictly bolt off old bolt on new?
I like seeing this thread come back to life!! My CLs is goin under a mini facelift /suspension/sway bar/paint/possibly taking OFF spoiler (any thought) and brakes would clinch the deal
#688
From an honest scale of 1-10 based off old stock brakes and now, hwere would each sit you feel ? No bologna!!
After readin all about caliper too big, you loose this, dont gain that, im curious
Its either these claiper of legends(nsx seem impossible to find within rea$on
#689
i just tried to do this with my 2nd gen TL, bought the kit fom a FB group. The seller told me 05 350z rotors? the rotors are rubbing against the calipers and arent sitting properly. do i need to use maxima rotors ? i think the adapter is from fastbrakes but not sure. how many other adapter kits are made for this setup ?
edit....nevermind, went back and saw you had similar issue in post #670, im just not sure how old my kits are, gonna try maxima rotors now. Thanks!!
#690
Is everyone just using a banjo bolt to attach the line to the caliper?
I posted this on TSX club but havent gotten any response, figured I'd ping this community..
I got a set of RL calipers, 12.8 350Z rotors, pads, and the FFC brackets from a guy I know in trade.
After installing the parts at his shop I drove home and took the wheels back off to re-bleed the system, it felt mushy.
I discovered that the brake lines to the calipers were lightly seeping.
I went and got new copper washers and after installing they were still seeping, I read that the factory banjo bolts for the TSX are too long and some people either bought new bolts or added another washer. With another washer, they still seep.
I also came across this post which is concerning, basically using the banjo bolts on these calipers isn't what they are designed for.
So I'd like to do a set up like this...
(The site that had this image didnt have the details about the brake lines)
Can anyone direct me as to what exact fitting that is between the caliper and brake line? I'd like to just use some rubber generic hoses if I could.
It's hard to find images of the back of the caliper with the OEM lines but here is an example.
#691
More Information for A-1 CARDONE 193182
Psybin (07-21-2017)
#692
Thanks!
So maybe I could use this hose -- https://www.carid.com/big-end-perfor....html#features
on this adapter -- https://www.pegasusautoracing.com/pr...asp?RecID=4191
I'm not sure the size of the fitting in the car that the other end of the hose mates up to, looks like maybe M10x1 by checking brake line replacement parts specs.
Or something like this if I could figure out the sizes and not bother with the adapter.
#693
Thanks!
So if I find that fitting I could possibly mate it up to something like this?
https://www.carid.com/big-end-perfor...276845034.html
https://www.carid.com/xrp/xrp-brake-hose-323293045.html
I'm not sure what size the other end of the hose is in the car.
#1 ($43.07ea) or #6 & 7 on the link below. They are only $8.10 each and may sort your issue with one shot.
https://www.acuraoemparts.com/auto-p...lines-vsa-scat
I'm not sure either of the size on the other end. The link below indicates a female M10 x 1.0:
http://www.rockauto.com/en/moreinfo....431663&jsn=349
#694
I thought about trying to find RL lines but I'm not sure how they are mounted on the car, I'll have to dig and see what images I can come up with.
Thanks for the links, now I can find them quickly.
And the AN adapter I linked wouldn't work, AN is a standard size, wouldn't work on the metric.
#695
Since I cant edit my posts here is what I've come up with. I'm not sure which route I'll go.
You need a 10 x 1.0mm male to 3AN male, then a 3AN male to 10 x 1.0mm female with a 3AN hose in between (each side female), unless I can find a hose like the one pictured that has 3AN on one side and a 10 x 1.0mm female on the other side.
That or use the RL hardware and try to bend it as needed.
Or use a shorter banjo bolt kit from Fastbrakes, which is supposed to be fine, but I'm still leery.
#697
#699
Sorry to bump super old post... Can anyone confirm if RL calipers are interchangeable Left and Right side? I have a brand new one in my hands right now. With the exception of the bleeder pointing up/down, it looks symmetrical.
#700
I am dumb
Don't see why they couldn't be installed either way though. They're pretty much symmetrical; just two bolts holding them on.
619rcr (08-03-2022)
#701
Main reason I asked is the other one is backorder with no eta. If interchangeable, could order a second of the same side. Perhaps even tap the recessed spot, idk?
#702
I am dumb
Cool, was looking at this one. It has slight recessed impression on the opposite end of bleeder. Was thinking the same casting was used and just tapped for left or right.
Could always just order some used ones and try your hand at painting, lol. Lesson learned: paint will go through masking tape.
#703
Word... I do have black paint on the stock CL calipers. But, It's not nearly as nice or thick as this coating. Seems almost like plastidip. Plus it'd be nice to have a matching set. Fingers crossed on the other one getting back in stock.
Thefireball (08-03-2022)
#705
ummm?
Thefireball (08-15-2022)
