New Drivers Seat Upholstery
Old 02-11-2024, 05:20 PM
rickmiller's Avatar
My first post on this forum. I have an 06 TL. I am the original owner. Car has around 75K miles.
I have decided to keep the car since it is so fun to drive. First up is the upholstery. The drivers seat is in bad shape.
I removed the seat and have started removing the cover.
Seat Removed
This is what I am going to repair. I have the new upholstery ready to install after I remove the cover.
And a pic of my car 06 TL
joeyj (02-12-2024)
Old 02-12-2024, 04:45 PM
rickmiller's Avatar
Upholstery Progress
Separate the seat bottom from the seat back
Cover removed
Old seat cover
Legend2TL (02-13-2024)
Old 02-13-2024, 12:46 PM
AZ Community Team
Legend2TL's Avatar
Received 4,031 Likes on 2,507 Posts
Where did you get your seat covers from? Thanks in advance.
I need to do the same to the camel seat covers in my '05 6MT, I've replaced the bottom heater in the driver's seat so know how to get the covers off.
Old 02-13-2024, 03:19 PM
rickmiller's Avatar
US Auto Seat Cover
USAutoSeatCover.com
Old 02-15-2024, 03:22 PM
TVL65's Avatar
Acura should be embarrassed for using such crappy, cheap, and paper-thin leather back then. EVERY TL gets cracked seats.
The following 2 users liked this post by TVL65:
Legend2TL (02-17-2024), rickmiller (02-15-2024)
Old 02-17-2024, 01:54 PM
rickmiller's Avatar
Cover is on. Not worried about the wrinkles I am positive they will smooth out once it warms up and the sun bakes it. It's pretty cold around here now.
TVL65 (02-19-2024)
Old 02-17-2024, 03:00 PM
Received 1,736 Likes on 1,392 Posts
Just curious, are you using hog rings or zip ties as fasteners?
Old 02-17-2024, 03:30 PM
rickmiller's Avatar
Hog Rings, zip ties are not the way to go
Old 02-17-2024, 04:33 PM
That's what I used when I replaced the driver side seat cover on my CL-S6 last year:
Here are a few pics of my CL-S6 driver side Lseat.com replacement install:
No perforated leather, unfortunately.
In the car, the color was a pretty good match.
Passenger side factory seat:
An unrelated obligatory S/C'er pic:
rickmiller (02-17-2024)
Old 02-17-2024, 06:07 PM
AZ Community Team
Legend2TL's Avatar
The 3G has a few areas of poor quality in materials, front dash cracking/splitting, headliner glue failing, poor leather seat covers, Panasonic radio CD/DVD failing, black vinyl covered exterior trim,.....
This spring I'm gonna replace the seat bottom for both front and rear.
Old 02-17-2024, 08:05 PM
rickmiller's Avatar
yup doing the rear seat bottom next
Old 02-19-2024, 12:58 PM
AZ Community Team
Legend2TL's Avatar
Are you replacing the seat backs or leaving them as is?
Mine are in good condition so I'm figuring to just leave the seat backs alone and replace all three seat bottoms.
Old 02-19-2024, 01:03 PM
AZ Community Team
Legend2TL's Avatar
zip ties are not strong enough over duration and use. Know someone who used them on a Lexus LX450 seat reupholster and many failed after a year or so.
Old 02-19-2024, 01:24 PM
John from PA's Avatar
I agree with this comment. I can;t speak to an Acura seat construction, but what are typically used are called “hog ties”. These are metal rings that are clamped in place with a dedicated design pliers. Amazon has a kit for about $17, take a peak and see how it might work.
Hog tie kit Hog tie kit
. Scroll down once at the link; the kit usually has several hundred of the rings and the crimping pliers.
Old 02-19-2024, 07:58 PM
rickmiller's Avatar
Originally Posted by John from PA
I agree with this comment. I can;t speak to an Acura seat construction, but what are typically used are called “hog ties”. These are metal rings that are clamped in place with a dedicated design pliers. Amazon has a kit for about $17, take a peak and see how it might work. Hog tie kit. Scroll down once at the link; the kit usually has several hundred of the rings and the crimping pliers.
Exact tool I use
tlmailman
01-03-2024 05:01 PM
pault57r
12-31-2009 10:44 AM
Severin
10-22-2008 02:11 PM
Eisenhulk
08-26-2005 11:15 AM
Quick Reply: New Drivers Seat Upholstery
