Power steering whine on 05 RSX base
I changed the power steering pump on my 2005 base RSX with a remanufactured ebay purchase, and it's still squealing. Not as bad, but still squealing. If I spray lube into the front bearing of the pump it stops completely for a minute or so. The old pump did the same thing if I sprayed lube into the front bearing - so I thought it was the pump. I don't see any bubbling in the reservoir. I saw some of the posts on leaks in the lines and possibly in the rack, but if the noise stops when I spray lube into the bearing behind the pulley when it's running - do I have a bad remanufactured pump?
SupremeOpinion
2G TSX Problems & Fixes
02-08-2016 06:16 PM
