'04 TL code questions
Old 06-17-2019, 09:41 AM
skierz's Avatar
'04 TL with 179K miles is throwing the following codes:
25-1 YAW rate sensor malfunction
61-1 battery voltage malfunction
P2197 O2 sensor signal biased / stuck lean Bank 2 Sensor 1
The CEL light is on most of the time as well as the Airbag light on the left side of the speedometer window. Also the car surges fairly consistently while accelerating. Are these codes relative to that? Thanks.
Old 06-17-2019, 10:01 AM
Received 16,260 Likes on 11,971 Posts
troubleshooting 101, tackle one problem at a time.
figure out the charging issue...bad alternator? bad ground? bad battery?
once you figure that out; the other issues will fall in line and will be easy to diagnose
Old 06-17-2019, 10:56 AM
skierz's Avatar
Thanks justnspace. Being a VERY novice wrencher, what would be the best way to go about checking these things? Bringing it to my (trusted) mechanic? I'd like to avoid that if possible in the spirit of saving $$$.
Old 06-17-2019, 11:21 AM
Received 8,584 Likes on 6,630 Posts
Replace your battery.
Old 06-17-2019, 11:34 AM
I'd start with the battery. How old is it? Is it outputting the correct voltage when the car is off? 12.2-12.4 volts.
Next, i'd check the cables itself. Are they corroded? Are they making good contact with the battery?
Next, look at the ground wires. Are they corroded? Are they making good contact with the chassis?
Then have the alternator checked at AutoZone. Check the ground wires there as well.
ace2525
03-08-2012 01:09 PM
piggydog
02-11-2010 11:05 AM
tsxnation
04-19-2007 03:30 PM
Trevor
06-28-2004 05:23 PM
projextion
07-21-2002 04:43 PM
Quick Reply: '04 TL code questions
