RDX Home link Garage Door opener range
Old 03-18-2017, 11:01 AM
dawild1's Avatar
The range of the Home link is so bad I need to use a separate visor mount opener to do the job. Is there anything that can be done to fix this problem?
Old 03-18-2017, 11:39 AM
markAZ's Avatar
This had been discussed a couple times here...do a search to find the threads. IIRC, there's a TSB about it but I don't remember the details.
Does your opener have LED bulbs in it? They've been known to produce interference that blocks the signal from the remote.
Old 03-18-2017, 09:04 PM
RDX-Rick's Avatar
This is the TSB (assuming you have a 2013-2016 RDX)
Old 03-20-2017, 05:22 PM
3rd Gear
mcgsxr's Avatar
Odd. I can get mine to work from at least 2 houses before mine. Hope the TSB helps you out.
Old 03-21-2017, 08:04 AM
kipsy's Avatar
the tsb re-orients the homelink sender, it is pointing left to right instead of north. thats probably why it works from 2 houses down.
Old 03-21-2017, 06:30 PM
romer's Avatar
Mine works from at least three houses away. 2016 AWD Advance.
maharajamd
10-20-2016 04:10 PM
maharajamd
10-18-2016 12:14 PM
RDXMac
10-12-2016 02:17 AM
Ossman14
10-07-2016 09:05 PM
soopa
04-14-2001 12:08 PM
Quick Reply: RDX Home link Garage Door opener range
