software update
Old Mar 1, 2017 | 05:19 PM
hovbuild's Avatar
software update
for the transmission shudder. There is a tsb about this and it states that the tranny fluid goes bad quickly due to high temps. They say a fush and an update that will run the fluid cooler is the fix. Wondering if it is out yet.
Old Mar 2, 2017 | 12:58 AM
Beamer's Avatar
I am experiencing this exact same problem between 60km/h to 80 km/h. The dealer Lougheed Acura recently flushed the transmission and stated they did a software update. It made no difference. The stutter is even worse during turns on a city highway. I am also experiencing a lot of vibration when I'm sitting at intersections, the whole truck vibrates, almost like the truck is struggling to breath.
Lougheed Acura also changed the Engine Air filter, did a transmission service and software reset. It did not solve any of the problems. I'm also including a picture of what my Air Filter looks like after it was changed by Lougheed acura. The picture was taken about 12 hours ago.
Old Mar 2, 2017 | 12:20 PM
kipsy's Avatar
begs the question - when was the last time the filter was changed ?
what does dealer want to do next if the issue is still happening ? i would get it documented.
Old Mar 2, 2017 | 06:07 PM
Beamer's Avatar
Lougheed Acura said the truck was leased from them in 2013 and fully serviced by them throughout the lease. The filter looks like its the same one since it left factory, doesn't appear to ever been changed during any prior servicing or the 125 point certified used inspection.
Old Mar 18, 2017 | 10:15 PM
tal's Avatar
tal
I have the same issue and like to know when the fix is in.
Old Mar 19, 2017 | 12:44 AM
Beamer's Avatar
The transmission shudder on my RDX turned out to be a Propeller shaft.
Based on google searches, appears to be a common Acura RDX problem.
Old Mar 20, 2017 | 09:51 AM
tal's Avatar
tal
Was this Service Bulletin 14-001 that you had done to your RDX?
Old Mar 20, 2017 | 11:00 AM
vetdude's Avatar
Yep, our 2013 had the same problem. Dealer replaced the entire "prop" shaft (drive shaft) a few weeks ago with the new "upgraded" shaft and all is well again. Apparently, there are some rubber couplings or bushings where the shaft connects to the front and rear diffs that get hard during very cold weather causing the vibration.
Old Mar 20, 2017 | 02:26 PM
Beamer's Avatar
Invoice says Bulletin A-2-14. There's no other explination.
Old Mar 22, 2017 | 07:31 AM
andysinnh's Avatar
'15 RDX AWD with 19k miles. I reported in another thread that I began to get some odd behavior with shifting at speeds that were similar to when the torque converter would engage/release. I had the TSB completed a couple of weeks ago (fluid change, SW update) and the problem was resolved. In my case the problem came on slowly over a couple of months, and other than the shift points it was smooth as silk. I'd say if the issue you're seeing is more prevalent across the speed range, then the prop shaft bulletin might be a more appropriate way to go.
andy
