Reverse Light Bulbs
Reverse Light Bulbs
Would these bulbs
Sylvania 168/194/2825 Premium White LEDriving Bulb
be OK for me to use to replace the OEM back up bulbs in my '14 RDX? I could use the extra light with my barely legal window tint when backing into my garage. I'm not looking for cool, I'm looking for more light. Any suggestions would be appreciated.
12W HID White 921 T15 Backup Reverse LED Lights Projector Lens Bulbs White | eBay
These will be a better option for you.
Would these bulbs
I have something similar. The problem is the way the bulb is positioned, the brightest part of the bulb (tip) is pointing to the side and not out. It makes a small difference.
I purchased these from a local speed shop in Central Jersey($60). Wish I had more info but that this moment i do not.
This was a very easy install and was all done within 10min for both sides. There no comparison between an LED and 15w HID IMO. The lumen output just isnt there.
The Original Shawdy
I swapped mine out this past week. I found the easiest way was to use light pressure with some bent needle nose. They came out like butter.
The Original Shawdy
Mine didn't come out by hand the first time and I was twisting the correct way. I even have small hands. Everything is new so it should be snug. Did my sub install and all the bolts/clips/plastics were tight.
Replacing the bulbs is cake though. Surprised how easy the RDX is to work on compared to my 14 TL SH.
I use this one
https://www.amazon.com/Philips-Brigh.../dp/B00P2D41OQ
See review here, Philips 7443 921/T16 T10 LED bulb review
Just FYI. I got this Philips bulb from Amazon and it does not fit my 2017 RDX
https://www.amazon.com/dp/B01I3OTWQ2...k20955-20&th=1
I have a 2013 model. Will that make a difference compared to the 2017 model? I don't know if I can justify paying $40 (12841) if I know the ones listed for $20 (921) will fit my 2013. Can someone confirm if?
rockyboy
12-06-2022 02:29 PM
BoricuaTL
04-08-2016 01:08 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
Greengecko
09-16-2015 08:19 PM
