Brake pads and rotors replacement
Old 11-06-2015, 01:13 PM
rdx158's Avatar
I have new R1 Concept premium slotted rotors and ceramic pads coming next week and I was wondering if a write up has been done to replace all 4? Thanks, kp
Old 11-06-2015, 01:24 PM
Received 16,260 Likes on 11,971 Posts
all modern brakes use a floating caliper design.
If you've done one, you've done them all.
- loosen or break wheel lug nuts loose.
- jack car up
- take off wheels
- remove caliper from caliper bracket.
- remove bracket.
- drill through rotor retaining screws.
- remove rotor. (might need a few bangs to dislodge)
- put new rotor on.
- attach caliper bracket and install bolts.
- torque bracket bolts.
- Align new pads and apply grease
- attach caliper to caliper bracket.
- torque caliper down
rossmo (08-12-2018)
Old 11-06-2015, 01:25 PM
Old 11-06-2015, 01:32 PM
Be a better driver
RedRyder's Avatar
These threads have some good info, the second evencontains torque specs:
https://acurazine.com/forums/fourth-generation-tl-2009-2014-123/changing-rotors-questions-916068/
https://acurazine.com/forums/diy-faq-161/diy-brake-caliper-painting-776569/
More threads:
https://acurazine.com/forums/search.php?searchid=17713669&pp=40
And here are numerous DIY videos for variousAcuras that should cover it all: https://www.youtube.com/results?search_query=acura+rdx+brake+job+
justnspace (11-06-2015)
Old 11-06-2015, 02:47 PM
Jdrum1's Avatar
I've always used an impact screwdriver for the rotor screws. I don't put them back in, but keep them just in case I ever need to mess with the brakes in the future (nice having the rotor locked in place.
Old 11-06-2015, 06:08 PM
Kaputnik's Avatar
Good time to bleed brake lines to replace fluid if you are due.
Old 11-07-2015, 02:52 PM
DRR98's Avatar
Ceramic pads eat rotors.
I replaced our pads at 98k mi using o/e pads.
Upgraded pads from Performance Friction, EBC Greenstuff are good aftermarket choices.
Amazon.com: EBC Brakes DP61193/2 6000 Series Greenstuff Truck and SUV Brake Pad: Automotive Amazon.com: EBC Brakes DP61193/2 6000 Series Greenstuff Truck and SUV Brake Pad: Automotive
Most Important When replacing pads and rotors-
Pad and rotor prep (bedding and seasoning)
http://baer.com/gallery/plog-content...-bedding-1.jpg
http://baer.com/gallery/plog-content...-bedding-2.jpg
http://baer.com/gallery/plog-content...-bedding-3.jpg
Old 11-09-2015, 01:59 PM
rdx158's Avatar
Thanks all, very helpful, kp
Old 01-12-2016, 11:44 AM
SinCity's Avatar
Tks!
Old 01-24-2017, 02:31 PM
drakescherer's Avatar
quick note. I did my rotors yesterday at 210 000 km, they apparently had not been changed once in their life.
PB Blaster works great, but my suggestion is to spray a bunch on, leave it overnight. Come back with a screwdriver, fit that into the bolt. Hit the end of the screwdriver with a hammer a few times, this loosens any leftover rust. Then hit it with an impact driver, I put most of my weight into the impact driver just to be sure I didn't strip the head.
As said by others, these bolts DO NOT need to be replaced. These were only installed OEM because they helped with assembly as the rotors didnt move around during the install. What I did to keep the rotors in place, was just use one of the quick clamps against the drum of the rotor, not the actual mating surface. This allowed me to reinstall the caliper bracket, new brakes and the actual caliper without the rotor moving at all. Obviously at this point the caliper held the rotor in place for me to reinstall the wheel.
Old 01-24-2017, 02:49 PM
Received 8,584 Likes on 6,630 Posts
If you had an impact driver, then why did you use a screwdriver and hammer...
fwjoe817
Texas
11-12-2015 12:44 AM
jswift2000
11-11-2015 03:12 PM
tr59210
11-09-2015 02:22 PM
copmagnet82
11-05-2015 01:17 PM
orangewhip
11-02-2015 12:58 PM
Quick Reply: Brake pads and rotors replacement
