Trans jerky
Old Sep 2, 2012 | 10:47 AM
Dubbl1's Avatar
Thank you Jeebus!
Trans jerky
Any other ZDX owners out there notice the trans seems jerky at mid gear? I've notice a very distinct jerking motion when traveling around 40-60 MPH. It's almost like the car is between gears and can't decide to shift. There are no noises or any other indications of issues, just an annoying jerking feel until I increase speed or romp on it. I plan to drop the car off at Acura this week and will post once they look at it, but was curious if anyone else felt this? I know they had trans issues in past years, but this doesn't match the symptoms that issue caused. Hopefully just a quick program download to revamp, but we'll see. Let me know if you have felt this and if you did anything about it. If you haven't noticed it feel for it when you drive and let me know if it is noticeable once you look for it. I can't be the only one, so hopefully it can be fixed quick and easy...
Old Sep 2, 2012 | 11:15 AM
Dubbl1's Avatar
Thank you Jeebus!
FYI... I've not found info on the ZDX, but definitely an ongoing issue for 2010-2012 MDX's. I assume same trans is in my car, so probably the same issue. I'll get a hold of Acura and address it, still curious if anyone else has felt this or had the issue fixed.
Old Sep 2, 2012 | 03:19 PM
Sandro's Avatar
Does it look like this service bulletin?
http://www.mdxers.org/forums/74-2007...converter.html
If yes then go to your dealer and do it
I feel that the tranny jerks when you swiftly release the gas pedal after accelerating and sometimes when shifting from 1 to 2 on mid RPMs but thats about it. What you described looks like the bulletin
Old Sep 2, 2012 | 03:42 PM
Dubbl1's Avatar
Thank you Jeebus!
I agree after seeing this, will call Acura Tuesday to set-up an appointment and print this off in case they deny it. Thanks-
Old Sep 4, 2012 | 10:45 AM
Dubbl1's Avatar
Thank you Jeebus!
Dropping off the car at Acura for a program download and possible trans fluid flush as noted on the bulletin. Hopefully all will be well then, seems Acura knows the computer is not properly programmed for the torque converter but hasn't sent out a mass notification to owners.
Old Sep 8, 2012 | 12:27 PM
Dubbl1's Avatar
Thank you Jeebus!
Dealer seemed to fix it by following the bulletin. They downloaded the new trans program and decided to do the fluid flush while I was there just to make sure. All seems to be good now...
Old Sep 8, 2012 | 01:06 PM
Sandro's Avatar
as it should. congrats)
Old Sep 24, 2013 | 03:07 AM
michaelman's Avatar
6th Gear
What other major updates should be performed on the 2010 zdx?
Old Sep 24, 2013 | 02:49 PM
michaelman's Avatar
6th Gear
Is this technical service bulletin for the tranny/ torque converter programming something that all of us need to do?
I've read that the update just delays when it upshifts... Which makes the car more zippy... But should worsen the fuel economy? I've read some owners claim that they go from 19 avg to 14.5 average.
Old Oct 2, 2013 | 10:31 AM
Dubbl1's Avatar
Thank you Jeebus!
The dealership will only do the update if the car needs it. I do not know what my MPG was before the update, but I get around 17-18 now with most of it city driving. All I know is MPG was not a thought that came to mind because the update was necessary and there was no way I could drive it without it.
CL-S progression 01
Jan 26, 2016 04:15 PM
LeVeL
Oct 18, 2015 04:19 PM
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
steve
Sep 30, 2015 09:23 PM
flyromeo3
Sep 24, 2015 11:24 PM
