zaino?
Old Apr 21, 2003 | 09:22 PM
eighteight's Avatar
zaino?
quick question on zaino, i just bought zfx, i almost fell over when i seen how little the vile was. Anyway, i emailed sal and he said it should last about 20 ounces, anybody have any idea how many ounces it takes to do a car on average? The little tubes that come with the zfx are 2 ounces each, is 1 tube enough for 1 coat? or more? or less? thanks, i always think im using too much.
Old Apr 21, 2003 | 09:30 PM
Nicky Pass's Avatar
Fuct in the hed!
You're supposed to use 5-10 drops for every 2 oz. You don't have to use ZFX every time either!
Old Apr 21, 2003 | 09:36 PM
Six Shifter's Avatar
an adult perspective
I found that the first time I zaino'd my car, I used the the ZFX enhanced Z5, and one 2 oz bottle got me two complete coats for the car. When I switched to the ZFX enhanced Z2, I had some Zaino left over after putting on the 2nd coat. The next day I only filled the 2 oz bottle just shy of 7/8ths full and I still had a small amount left after putting on 2 coats, which I used on the rims. My experience was that once you started applying this, you seemed to require less and less to cover the car during subsequent coats. This could also be attributed to the Z6 between coats which does appear to help slicken the surface, thereby allowing a little to go a long way as Zal states. if this helps ...
Old Apr 22, 2003 | 12:42 AM
ChodTheWacko's Avatar
Moderator Alumnus
I suspect you should be able to get a good 3 coats in with a 2 oz bottle. Zaino should be applied extremely thinly, and you will probably be putting too much on your first time however.
Old Apr 22, 2003 | 01:29 PM
stejus's Avatar
Manny Tranny
I just did Z5 and Z2 over the weekend.
1oz of Z5 and 5 drops of ZFX. Shake like mad!! I got three coats (very thin of coarse).
then next day (24 hours after the last coat)
1oz of Z2 and 5 drops of ZFX. Shake like mad!! I got three coats.
Results!
Old Apr 22, 2003 | 05:20 PM
eighteight's Avatar
thanks for all the replies. What do you mean "you dont have to use zfx every time"?????? i thought you were supposed to use it everytime you put on a coat of z2 or z5
Old Apr 22, 2003 | 05:42 PM
the ZFX is an accelerator for the drying time of the Z'n' you're using. If you don't want to be able to put on multiple coats in a relatively short period of time, you can Zaino without ZFX. all this means is that you'll have/want to wait longer for each application to dry before buffing it off.
Old Apr 26, 2003 | 12:21 AM
darrinb's Avatar
///M POWER
i can prolly get 2 coats per ounce, thin is the key
Bill97Z
Wash & Wax
20
Oct 24, 2009 07:52 AM
mantis23
Wash & Wax
Feb 11, 2002 07:14 AM
Rustito
Wash & Wax
Dec 29, 2001 03:32 PM
Nicky Pass
Wash & Wax
Oct 20, 2001 03:42 PM
fastdriver
Wash & Wax
Jun 6, 2001 04:09 AM
