Winter Wash Tips
Winter Wash Tips
Hi everyone,
With the winter here in the Northeast, I was thinking about how i was going to take care of my car. I may get it detailed a few times, but don't want to do that too much. How does everyone take care of the car? I'm referring mainly to washing and keeping clean, not so much winter prep like waxing. Do you go to the quick washes and bring your supplies? What's the best way to do a quick 30-45 minute cleaing when it's 35 degrees out?
3G TL/2G MDX Owner
rubber kitchen gloves, two bucket ONR wash, done. if the car is really gross a good rinse with the hose when the temps get above freezing (or take it to a self wash place to rinse), then proceed with ONR wash.
moabizzi
In NJ its around 40, so i just layer up, rubber glove under the wash mit and try not to get wet. just try to avoid the windy days. i bought a soap dispensing spray gun thing for my hose, i dont have a pressure washer, i first rinse the car, add the car wash to the spray gun, spray the car, go over it with a mitt, have a bucket with grit gaurd in it. then rinse, move the car back about 10 feet, dry it off, then into my garage for waxing.
Unless I can do my normal wash / dry in front of the house all I do is weekly I go to the self wash / spray wash and just use thier pressure rinse and get as much of the crud and chemicals as I can and just let the wand flood as much off and out of creavaces as I can.
Tech12 (12-02-2012)
I think this might be the way for me as it gets real cold.
def waterless or rinseless wash.
if it was freezing out heres what i would do.
cap full of ONR and a gallon of water in a sprayer (you can pick one up from home depot really cheap).
spray the car liberally. this should get rid of a lot of the heavy dirt.
2 buckets of warm water and grit guards.
ONR in one bucket and plain water in the other.
wash with a mitt and dry with a MF towel.
done.
done.
