Windows + sealant question
I know with zaino you can apply the Z2 directly on the windshield and it has pretty nice results. The wipers glide across the windscreen easier and rain beads away so easily. I was interested in trying this using Poli-Seal since its polymer based. I was curious if anyone did anything like this or if this is feasible at all. Would you use machine(if so, which pad/speeds) or hand application?
Be careful with waxing the windshield. It can cause unclear images and sights! Use the proper stuff like Rain-X or Xpel...
KBPftmfw
http://www.rainx.com/Products/Windsh...t/2_In_1.aspx#
I got the one in the spray bottle. No matter how much/little I use or the type of microfiber it smears.
Received 6,470 Likes
Eks, I've had great luck with Invisible Glass. This is not a polish, but it really keeps the windows clean and seems to protect some too.
After the rain-x has dried try throwing just a few drops of water on the wind sheild before you buff it off. That should remove the streaks. I have used it for many years with no streaking at all. I have never used the 2 in one product. I clean the glass first then apply the Rain-x from the small squirt bottle. I either do it right after washing the car or I use Invisible Glass to clean it.
Hope that helps.
Hope that helps.
I have this Rain-X crap and all it does is streak and smear. I won't be getting it again.
i actually just use my FS UPP on all my windows, after 6 months its still beading great and works extremely well.
I can't stand Rain-x is always a mess and usually once you use it you have to continue to use it.
I've used Aqua-Pel with great results as where I live has hard water and my main reason for using it was when I washed my car was to prevent water spotting, seems to do it's job for that and as for it's effectivness in the rain, I don't even have to use my wipers most of the time and I live in Oregon where it rains almost 9 months out of the year!!!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
wcimo
09-21-2015 10:55 AM
ahsm
09-09-2015 08:35 AM
