Weed whacker car wash left it's mark(s)
C'mon, man! Row yer own.
I know, I know. I went into a filling station car wash that had those weed-whacker spinning wash-things and, yes, it left about 275 million little scuffs in my finish. None of them goes through the paint, I'm assuming they're all blemishes in the wax and clearcoat. Should be able to polish those out, yes? I don't have a random-orbit polisher, just elbow grease -- that should do it, I think.
I have Meguiars 3-step system -- Paint Cleaner, Polish, and NXT wax -- that should do the trick, don't you think?
I will never -- NEVER -- use the friggin' gas station p.o.s. car washes ever again. I have sinned . . .
Former Sponsor
I would recommend a membership to 24 hr Fitness also......Shame on you.......!
You could go for some clay to begin with, then Poorboys SSR 2 and and a nice Polymer protectant.....Apply with a cotton applicator for additional bite, and apply the Polymer with a foam applicator. Remove all products with a quality Microfiber polishing towel......
Thanks, guys. Is the Poorboys better than (or different from) Meguiars Scratch X (which I have)? Also, if I went ahead and got a PC polisher, are they fairly straightforward to use? Would I get better results (in this case, and also in general) with a Porter Cable than by hand? I'm not adverse to using this incident as a reason (excuse?) to buy a decent polisher, but I've never used one and certainly don't want to do more harm than good.
Thanks for your advice!
Former Sponsor
Your results will be 10 fold with a PC. If you only polish out the scratches, your going to see an impressive difference. The price for proper products can be paid for by 1 professional detail.
The PC's are very easy to use and have about a 10 minute learning curve. There plenty of folks here and on other car care forums who can help you learn its function, as well as capabilities. Im sure theres as amenable to assisting you as I will be, if need be.
Just dial 1911
1 Post
Personally, I dont see how he's going to remove swirls by hand. I've done enough cars now to know that if I didnt have my PC, their would be no way. In fact, I'm going to buy a rotary here pretty soon. I did a white Mustang that was swirl city and it took me entirely too long to do. And this was using a PC with an orange DAS pad and SFX-1! It was a huge improvement when I was done, but I didnt get every swirl out, so I was dissapointed...
Bottom line Peter, you might see some improvement, but without a tool to assist you, I think its a waste of time. Take it to a pro or get a PC.
Driver/Detailer
By hand, you can use scratchX to improve but not totally remove the scratches. If you have a PC, then go ahead with Poorboys. When I use my PC, I use Poorboys SSR2.5 with a yellow Propel pad. Works much better than ScratchX and my hand.
Thanks so much, guys. As soon as I scrape together a few bucks, I'm going to get a PC and pads, some Poorboys, and attack. I did the car by hand the other night, using the Meguiars paint cleaner, polish, and nxt wax. Looks 1000% better than it did, but obviously still has swirls and super-fine scratches you can see when the sun hits it right.
I don't show the car but I do take exterior care and appearance seriously and, having found this forum, I never realized how much better a car can look than just the typical wash-and-wax. So, in the long run a PC buffer and pads is a great investment.
Any advice on the types (I guess they're classified by color) of pads a guy should get for scratch repair and then general finish maintenance?
Gents, I know this has been addressed somewhat (I've searched on it), but I wanted to ask a specific question: is there a difference in polishing performance or ease of use between the PC 7336 (with the appropriate-sized pads) and the PC 7424 (with the appropriate--sized pads)? As I understand it, they simply come with different counterweights, requiring different sized backing plates and polishing pads, but are otherwise the same machine. Correct?
The 7336 is available locally for about $40 less than the 7424, that's why I ask.
Originally Posted by Hawhyen51
As Joe said, the difference is just the CW's. Here's a FYI about pads. I can vouch for exceldetail's comments, there is a lot of info to be gotten here given by experienced people. You're gonna be addicted.......
Driver/Detailer
Depends on the product that you are using. I use SSR2.5 with a yellow pad for swirls, SSR2.5 with a green pad for minor swirls, SSR1 with a blue pad for fine polishing and #21 with the gray pad.
Former Sponsor
Driver/Detailer
SSR is the swirl remover, while the pads are by Propel. Get them from exceldetail.com. I want to try the Propel2 pads. My yellow is biting the dust because someone used it and pressed down too hard.
Driver/Detailer
Originally Posted by exceldetail
Nice quiver !
What is the difference between orange and yellow? On the abrasive scale, orange is higher but I've heard of people going for orange because it is softer!
Anyone use the SFX series pads? It said SFX-1 is for removing swirls so I bought it. The PC kit comes with the SFX-2 polishing pad so I was thinking use SFX-1 to get rid of swirls and then use the SFX-2 to polish. This is my first time using foam pads to get rid of swirls so not sure what kind of results I'm going to get.
Just dial 1911
1 Post
Its been my experence so far that heavy swirls are very difficult and time consuming to remove with a PC. I'm about to purchase a rotory for those jobs. Not saying it cant be done with a PC, but it does take longer and will chew up your pads faster.
Originally Posted by joerockt
It really depends on the amount of "swirllage". That yellow pad should be fine, but I would start with a light swirl remover first.
I miss my 03 CL-S :(
FWIW, Autopia has a 15% off coupon code (SONUSPOLISH) on all Sonus polish, foam pad and polisher products.
I recently got their SFX pad kit with SFX 1/2 and a clay bar for well under $100 thanks to the 25% coupon code someone posted here. I've yet to try them but the quality of the materials seems rather good. They could skip the fancy packaging and offer it a little cheaper if you ask me.
edit: You can get the 7424 for ~$100 at Lowes if you get the 10% coupons they mail out every other week - but the combo deal of PC+pads at autopia is pretty good if you ask me.
FWIW if you want to do all your shopping at Autopia their polishes are pretty good too - very comparable to the SSR series. I picked up all three when I won that contest they run and have been using them quite a bit. Cheers (and have fun!).
Just dial 1911
1 Post
Just dial 1911
1 Post
Yes, I was talking about the Sonus line of polishes. I find they work well and don't dust as much as the SSR line.
OK well then we've just had different experiences.
Of course keep in mind SFX-1 is the most abrasive of the Sonus polishes and would be on par with SSR3 (which is about the chalkiest polish I've ever used). But ya, either line will serve the OP well. I only mentioned Sonus because he seems to be doing his shopping at Autopia, so it would mean he'd be able to get his polishes from the same place.
Oakes
Wash & Wax
10-12-2015 11:17 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
