wax and rain
As for claying, I went to a local car place and personally grabbed the mothers kit as it was the only stuff there.
All you really have to do is:
1. Spray the surface with the Quick Detail spray they provide.
2. Mold the Clay first in ball, then press on it till it forms into a disk / saucer
3. Then place the mold in your hand, spray a shot on the clay
4. Rub the surface Up / down then left to right, always make sure it glides easily.
5. Wipe off and check the surface, repeat if necessary.
A note on the mothers clay kit, the stuff is pretty fine and it's not super abrasive, but it should take off most contaminants and water spots etc.
Originally Posted by MyPearl02
do you have to push on it very hard or is it pretty easy
Pick up some foam detailing swabs to get the areas such as around the emblems. At worst you can clean them with some bathroom cotton swabs but be careful since they can scratch the finish if you are not careful.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
SinCityTLX
55
10-11-2015 01:20 AM
