water nozzle
Old Jul 31, 2003 | 10:56 PM
blahsome's Avatar
water nozzle
Do you guys just use regular water nozzles also used for garden and lawn, or are there specific ones better suited for washing the car?
Thanks.
Old Jul 31, 2003 | 10:59 PM
TWong1200's Avatar
regular nozzle here while washing. but no nozzle at all during my final rinse.
Old Aug 1, 2003 | 11:26 AM
MikeMa's Avatar
No Longer a Poseur
The water pressure at my house sucks, so it takes me forever to rinse with *any* sort of nozzle.
I bought a Simoniz 1650 pressure washer, and it works very well. It boosts the pressure of water to acceptable levels (about 1000 PSI for the regular nozzle--the "blaster" nozzle goes all the way up to 1650, but I'd never point that sucker at my car).
As a bonus, the pressure washer saves me a great deal of water too (since there's lots of air going through, and it moves the soap and whatnot off the car faster). I noticed this the first time I washed my car with it. Usually, I have a huge puddle of water running down the driveway, and it looks like the Amazon flowing down the gutter. But, with the pressure washer, there's only a small puddle at the end of the driveway and a trickle going down the gutter.
I did a full on wax job (claying, sealingX2, waxingX2) on my car and took it on the highway. I got back home and there were lots of bugs on the front. So, I fire up the pressure washer, give it a quick blast, and all the bugs are gone. I do know about the dryer sheets thing, but I usually only resort to that if the bugs aren't coming off with the washer.
Old Aug 1, 2003 | 12:08 PM
blahsome's Avatar
Actually now that I think about it, I don't even remember when was the last time I used even a regular nozzle. So how does it work again? If I release the nozzle, won't the water bust the pipe since there's no way out?
Old Aug 1, 2003 | 05:21 PM
MikeMa's Avatar
No Longer a Poseur
You better go check your basement....it's probably flooded since you shut off the taps outside!
Old Aug 1, 2003 | 09:32 PM
Homer2's Avatar
HAHA - that was nice . .. good one.
Im also on the side of NO nozzle.
Let the water stream over the car - hold the nozzle in the palm of your hand (to prevent it from touching the car) - and keep your hand close to the car. lwet the water stream - you will be very impressed with how little water is left on the car . .
Old Aug 13, 2003 | 10:00 AM
TSXnT-dot's Avatar
I'm another one for letting the water stream freely.. pressure washing is very hard on a car's surface.
Old Aug 13, 2003 | 10:56 AM
hobbestec's Avatar
What dryer sheets thing? Do you take bugs off with a dryer sheet?
Old Aug 13, 2003 | 10:16 PM
MikeMa's Avatar
No Longer a Poseur
This was a hint on the forums a while ago. Take the Fabric Softener dryer sheets, wet them, and rub them all over the bug splatters on your bumper/headlights. After rubbing it in for a bit, the bugs should start coming off pronto.
I rub the bugs with the sheets a little bit, and then come by with the pressure washer.
It's a really great hint...and apparently, it's gentle enough not to strip the wax, unlike the Bug and Tar spray. I'm not sure I'd try this on the windshield, though.
Old Aug 14, 2003 | 09:56 AM
dabuda's Avatar
its just like a regular faucet, you turn it off and the water pressure is still there but it shouldn't cause your pipes to bust...i don't know much about plumbing but you should be ok
Timmy18
Oct 17, 2015 03:58 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
STL TL-S
Sep 23, 2015 08:52 PM
