Wash after polishing?
Boom goes the Dynamite
After polishing you will have a lot of "polish dust". The only way to really clean it off is to wash the car afterwards. Then after waxing you end up with a good look.
Former Sponsor
If you have an air compressor and soft tip, it would help. After polishing client cars I always blow the surface free of dust anyway, even if its a very low dusting product......
I'm Baaack!
I use a 50/50 mix of water and isopropyl alcohol w/ a mf to just wipe it down. It evaporates quickly and doesn't leave any residue so you can move on to the next step quickly w/ minimal effort.
Just dial 1911
1 Post
I think it really depends on what product your using. I have yet to see Zaino flake up on me. And even if it did, I wouldnt wash it again. Just use Z6 and wipe it down.
Team Nighthawk MechE
Originally Posted by joerockt
Why would you do this? Your removing what you just put on.
No.... A polish is just that, a polish. It leaves behind no protection. That's what the sealant and/or wax is for.
That being said... I see that the Z2 is a labeled as a polish. Does it leave behind protection? I think it does... Does it have any cut to it? I know the polish I use does not leave protection... Once again, the clarity of the Zaino product line amazes...
Just dial 1911
1 Post
Zaino has great protection to it (can last 4-6 months), but its not a "cleaner" polish. I know that Klasse AIO is a cleaner polish, but it also leaves a protective acrylic coat. Klasse SG helps with the longevity AFAIK.
I really cant think of one polish out there that dosent leave some kind of protection. Maybe some of the abrasive polishes? Like SFX-1 or SSR2?
Does Sal have a product to remove old wax or just the Dawn method? Does he have a product to remove minor swirls or is the Z2 to simply fill them in and provide protection...
Sorry for the minor thread
You're correct, a true polish will remove old wax and improve imperfections.
The thing is that is misleading is that the Zaino Z2 is labeled as a "polish" when it is actually a sealant.
Sal recently released Z-PC which is an actual polish/paint cleaner and can be used prior to a Zaino Z2 or Z5 application without a wash.
Just dial 1911
1 Post
Originally Posted by SK2003TypeS
Correct. FWIW, I've used AIO as a base for Zaino Z2 and had some great results. A lot of Zaino users have been using this combo lately with success. Now that the Z-PC is out in the market, people seem to be going that way since it was designed for the product line.
Life's a beach
Do tell?
I will echo the comments above. "Polish" means an abrasive mixture to remove a microscopic layer of clearcoat to get rid of the stains, imperfections, swirls, etc. "Cleaner" has chemicals to remove same. A "Cleaner-Polish" is an aggressive mixture to clean up and smoothe out the surface but leaves NO protection. AIO or "All-in-one" is just that.
Zaino, until recently, did not make a true polish. They made polymer sealants but labeled them as "polish" since the general population has bastardized the term to include waxes/sealants.
Zaino Z2, Z5, Z6 has no abrasives and only Z5 has a little filler. It is an excellent protectant. But, many people will put a wax with filler on top of it, especially black and darker colors, to handle the fine swirl marks that always show up on dark colors.
I recently discovered that Eagles' Wax-as-you-dry does a great job after washing my Zainoed TL. I really didn't expect it to be that good and easy. It's better than QD (Quick Detailer) or Z6 (Zaino Gloss Enhancer). Try it. And it's not a lot of money. It takes the "silvery" effect away that Zaino can leave on black.
Yea, I just bought a bottle of AIO. I wanted to save some time by not having to clay every 6 months. Once a year should be sufficent. Im also thinking about picking up a bottle of SG instead of using Z2. If I can get the results from one layer of SG as I get with about 3 layers of Z2, then I think im done with Z all together.
If you have Z2 and AIO already, why not try that combo. Not sure what you're more focused on, but I'm guessing it's durability. Either combo will give you a good amount of life provided you regularly wash the car. As for appearance, I like the classic AIO/SG on light colors like a beige or silver. I like AIO/Z on darker cars.
Just dial 1911
1 Post
Link.
Just dial 1911
1 Post
I think in general it's good to clay at least every 6 months, unless you have a true GQ that doesn't see too much road time. AIO wouldn't help you clay less.
Yea, durability is what I'm looking for. Z seems to be the best at it. Just wanted to save some time and not have to add several layers of Z2.
My wife has a silver VUE, and that is due for a 6 month. I think I'll try the AIO/SG on it and stick to AIO/Z2 on my CG TSX
Thats incorrect on the AIO. It leaves a layer of acrylic protection. Thats why its called a polish and sealant.
Link.
Link.
I didn't mean that it was just a polish.
I drive 1 mile to work
For me, Zaino seems to hold up longer than SG. For daily drivers, both products are great for durability.
The only way to find out what you like is to try out the different combos. Of course you can pick up Z-PC, which is the AIO for Zaino.
As far as layers, I'll do only 2-3. Anything more, I don't see a difference in appearance or durability.
emailnatec
29
09-28-2018 04:27 PM
SinCityTLX
55
10-11-2015 01:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
