using polish before waxing
went through a top notch car wash in our area that uses meguires' polymer polish wax. The shine was amazing even more so than after i wax. after having that applied first, then i waxed. even on a 2004 car the wax looks much better if polish first.
Originally Posted by floridaowner
this thread is not in the gallery section and thus not worthless. Do all polishes strip previous wax? Don't like the idea of taking wax off my car despite if it's been on there a few months.
IMO, you should be using a paint cleaner , or something like dawn, to strip off the old wax and all the dirt, etc anyways. You dont want to put wax over dirt.
well i clean my car prior to waxing. this removes the dirt. however that doesn't take off the old wax. if place carnauba wax on top of old carnauba I thought that would be fine.
just washing your car with regular car wash soap is probably not enough. IYou gotta take that old wax off for a really good job.
Let me give you an example. Take any RWD car that is white. Notice the tiny specs of rust from the rear brakes all over the rear bumper. Wash the car, specs still there. You have to clay to remove them.
i hear ya. washing and waxing a 2004 tsx seems to sufficient if you do it often. can't imagine the car looking much better at this time. i have a lease so hopefully this basic method should keep the finish looking good for the few years i have it.
How often do some of you clay a car? I only do it once, max twice a year. I usually wash with Sonax soap, then cleaner wax (Klasse), followed by caranuba wax (P21), and when claying, I will use a glaze (Klasse) between the cleaner wax and caranuba wax. I think my car is pretty damn clean and shiny lookin.
polish and waxes
Polishing and waxing are two seperate steps and do not serve the same purpose. A polish is to clean and bring back the luster or shine and depth to the paint. A wax seals in all the hard work of polishing you just did. To get the full effect of a polish you will need a Porter Cable Raondom Orbital Buffer. You can get the PC 7336 at Lowes for $109.
Proper detail steps:
Dawn wash
Clay
re-wash
Polish with PC
Wax
If you are happy with the Wal Mart brand stuff such as Meguires or Turtle wax than by all means stick to it. If you are looking for higher end products than try out Zanio or Einszetts line of products. Much nicer results and alot eaiser to use.
Dawn wash
Clay
re-wash
Polish with PC
Wax
pinnacle is higher end than zaino and let me tell you all you need is that and not all these fancy items like clay bars etc. to keep a 2004 car look great. www.pinnaclewax.com their crystal mist detailer also is amazing especially on nighthawk black.
clay bar a fancy item?
At $12 a bar I hardly consider clay a fancy item. But I do consider it a necesity in a major detail job. Claying is very important to the final look of your paint. If you perform the baggie test and it doesnt need to be clayed then you have have no need to waste your time. However, since your car left the factory in Japan I can assure you it has been on a cargo ship, a train and finally to the dealer by truck. Rail dust by train is the main contributor to rough paint as is the truck ride to the factory. Then your TSX sits on a lot for probably a month collecting dust and debris. Claying removes all of these "splinters" in your paint and it does so very easily.
As for Pinnacle being higher end than Zanio, pick up a copy of Guru Reports Wax Test, they have tested more waxes than you or I will ever have access to and Zanio won hands down on the durability and shine catagory.
If you are happy with Pinnacle then by all means continue to use it.
teh Senior Instigator
um, no, clay bar is anything but a fancy item. It is definately a necessety whether the car is new or not. New cars usually need them more from just transportation and things like rail dust, etc.
while pinnacle is an awesome item it's far from a miracle worker and won't remove contamination. All you will be doing is trapping that contamination in there.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
detailersdomain
Wash & Wax
Sep 3, 2015 10:56 PM
