Using Megiuars 105 and 205 combo
Old Jul 19, 2010 | 01:39 AM
adriand56's Avatar
After i clay my car, i want to use the 105 and 205 combo. Is that just a polish?? So after them do i need to apply a wax??
Old Jul 19, 2010 | 01:46 AM
CU2MIKE's Avatar
after 105 and 205, do a IPA (rubbing alcohol, either full strength or 1:1 with distilled water) wipe down. Apply sealant if you want, then wax.
Old Jul 19, 2010 | 01:49 AM
adriand56's Avatar
what wax would you recommend? and is the sealant necessary?
Old Jul 19, 2010 | 03:38 AM
CU2MIKE's Avatar
Sealant is not necessary, but from what I'm aware of, it does give more protection than wax. Blackfire's sealant and wax is a very very good combo. It is also pretty expensive though.
Old Jul 19, 2010 | 03:39 AM
CU2MIKE's Avatar
If cost is an issue then you can always try Menzerna powerlock sealant + poorboy's wax.
Old Jul 19, 2010 | 12:38 PM
Disbe's Avatar
You want to use a sealant because a sealant will last a lot longer then wax. I use Blackfire Wet Diamond. You want to use wax on top of the sealant. Let the sealant cure for at least 8 hours before waxing. Here is the sealant i use:
http://www.detailedimage.com/wax.php...P205/16-oz-S1/
I would also highly recommend you read Todd Cooperiders writeup on a full TL detail. You will learn everything you need to know and what the best products are for detailing our TLs.
http://www.detailedimage.com/wax.php...-pearl-part-1/
Old Jul 19, 2010 | 01:27 PM
exceldetail's Avatar
Former Sponsor
IF you want to use a wax, use it atop a sealant. My recommendation is wait at least 24 hrs before applying. Its often recommended to wait 24 hrs before applying an additional coat of Polymer, I see no reason not to follow that recommendation for a Nuba.....As for best products, its totally subjective......There's not necessarily a best, but there are products which are favored more often then others. My recommendation is stay with a high quality name brands, and the one's often recommended by other detailers, then find out for yourself, what your most favored is......chances are, you're going to take a few forks in the road.
Old Jul 19, 2010 | 01:40 PM
Former Sponsor
Do not expect miracles right off the bat. As with any new "refinishing" job, it takes time learning the ropes. The PC is just the easiest/safest of the choices available. Also, consider using product with extended working times, non/minimal dusting.
The #1 objective with the PC is, become comfortable using it! Not immediate results. They will come as the user becomes familiar with pads, products, & techniques.
08KBP_VA
Oct 22, 2019 01:55 PM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
Sep 17, 2015 10:16 AM
PortlandRL
Sep 14, 2015 12:01 PM
nuldabz
Sep 3, 2015 05:49 PM
