Using Megiuars 105 and 205 combo
Sealant is not necessary, but from what I'm aware of, it does give more protection than wax. Blackfire's sealant and wax is a very very good combo. It is also pretty expensive though.
You want to use a sealant because a sealant will last a lot longer then wax. I use Blackfire Wet Diamond. You want to use wax on top of the sealant. Let the sealant cure for at least 8 hours before waxing. Here is the sealant i use:
http://www.detailedimage.com/wax.php...P205/16-oz-S1/
I would also highly recommend you read Todd Cooperiders writeup on a full TL detail. You will learn everything you need to know and what the best products are for detailing our TLs.
http://www.detailedimage.com/wax.php...-pearl-part-1/
Do not expect miracles right off the bat. As with any new "refinishing" job, it takes time learning the ropes. The PC is just the easiest/safest of the choices available. Also, consider using product with extended working times, non/minimal dusting.
The #1 objective with the PC is, become comfortable using it! Not immediate results. They will come as the user becomes familiar with pads, products, & techniques.
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
nuldabz
Sep 3, 2015 05:49 PM
