Scratch Removal
Old Nov 9, 2007 | 08:35 AM
blassiter1's Avatar
Scratch Removal
I bought a 2007 Royal Blue TL about 3 weeks ago and absolutely love it. I have been very cautious about where I park it so that I can avoid the little dings that happen in parking lots. I still notice where I have picked up little scratches that only I will probably notice. These are not deep at all and may be where my wife hit her purse on the side while getting in or something like that. Is there a product that you guys would recommend to remove them?
Also, I paid for the paint protection from my dealer and I have found a couple spots on the trunk that appear to be acid rain damage that probably happened on the dealership lot. I believe that the spot is under the clear coat since I cannot feel it. Looks like a water spot that wont come off. Since this was done before the protection, is it still covered. Is there a way to get it out?
Thanks and I apologize if this is a repeat question but I am fairly new here and did not spot it right off when searching.
Old Nov 9, 2007 | 09:58 AM
Jesstzn's Avatar
Usually purses and a little dust will make scratches .... give ScratchX a go .. should work if your patient.
As far as the paint protection ... its pretty much a money grab from the stealership. On a new car I do the same of not better protection by just applying a sealant and its $100.
I'd get to the dealer asap with it and it will be interesting to see how they honor it .. make sure once its fixed up that you keep track of the spots to see if they come back because that may use a glaze with fillers and seconf time around tell you the coverage is a once only per issue thing.
I bet when the salesman sold you the protection he pushed it as a save all .. never have to wax again .. and if it was there before the protection it should be covered ... you didn't pay for a flawed car.
Old Nov 9, 2007 | 11:03 AM
blassiter1's Avatar
So can they even fix this without sanding it down and repainting that section? Is there a polish or something that can penetrate the paint?
Old Nov 9, 2007 | 11:27 AM
Jesstzn's Avatar
Usually water spots just etc into the very top of the clear coat and they should be able to buff the spot down then reapply your "special coating"
Old Nov 9, 2007 | 04:48 PM
steve9207's Avatar
Check out Quixx repair system. If you can't catch the edge of the scratch with your fingernail, then this product should fix it. It was rated #1 scratch repair system in Consumer Reports. exceldetail.com sells it (Pat's one of our AZ vendors). Or you can find it at your local Pep Boys / Wal-Mart. It's kinda pricey though - $15 for the kit. But you can do probably 20 or so minor scratches with it.
If you have a UDM / PC, I would say that's obviously the way to go otherwise.
Old Nov 9, 2007 | 05:14 PM
exceldetail's Avatar
Former Sponsor
I have one kit left, but have decided not to carry it any longer due to its prescence in friggin WALMART!!
Old Nov 9, 2007 | 05:24 PM
triggerman's Avatar
My local WalMart is selling it for $10.00.
Old Nov 9, 2007 | 07:25 PM
lusid's Avatar
FTW
Old Nov 9, 2007 | 07:32 PM
Former Sponsor
Yeah when ya buy the kits by the gazillion, you can do that. Now you know why I dont carry them anymore. i also gave the company a piece of my mind when I found out WM had them.......
Old Nov 9, 2007 | 08:06 PM
steve9207's Avatar
Pat, I understand what you mean & respect your decision completely. I would have done the same thing in your position. However, wouldn't you say based on your personal experiences the product works well? I believe you have a DIY on your page showing your results, which were pretty amazing to see acheived by hand.
To the OP, I still suggest you give this a try if you don't own a UDM / PC.
Old Nov 9, 2007 | 09:53 PM
Former Sponsor
Steve, no doubt, a good product to have in the arsenal.
Heres the same info that was on the site.....
Old Nov 10, 2007 | 12:46 AM
Hawhyen51's Avatar
I have no doubt the QUIXX System works quite well for longer and deeper scratches. If the scratches are minor as in this case, I would tend to use a spot cleaner/polish to correct the defect. And Patrick, I would have done the same thing - just a bitch to compete when one has assets to buy in volume.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
datadr
Mar 23, 2016 01:39 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
