Removing Flea from Car
Old Oct 20, 2009 | 11:11 AM
Porkipine's Avatar
'07 NBP TL
My friend thinks there are fleas in her car. Does anyone know how one would go about removing them? I've read that one can vaccum the car. Anything else that doesn't require a lot of time (more than 3-4 hr). I'm considering wiping down the seats with some diluted soap water and see if that helps. btw, the car have cloth seats. also is there any product that can clean the seats and help remove the fleas at the same time?
Old Oct 20, 2009 | 11:46 AM
exceldetail's Avatar
Former Sponsor
Drop a flea collor on some cardboard, under one of the seats!!
Old Oct 20, 2009 | 01:22 PM
Porkipine's Avatar
'07 NBP TL
doesn't the flea have to get close to the collar before it kills them?
Old Oct 20, 2009 | 01:30 PM
Former Sponsor
Good point, trying to take the least evasive method........I'd be willing to say if you vac the whole interior, your issues would go away. Im no flea expert, but Id be willing to state if they dont have something to feed off of, and/or are not next to something warm blooded, they will probably expire on their own.
Old Oct 20, 2009 | 01:34 PM
Former Sponsor
A little more info:
Using dehumidifiers with air conditioning and vacuuming all may interrupt the flea life cycle. Humidity is critical to flea survival. Eggs need relative humidity of at least 70-75 percent to hatch, and larvae need at least 50 percent humidity to survive. In humid areas, about 20 percent of the eggs survive to adulthood; in arid areas, less than five percent complete the cycle.[12] Fleas thrive at higher temperatures, but need 70° to 90°F(21° to 32°C) to survive. Lower temperatures slow down or completely interrupt the flea life-cycle. A laboratory study done at the University of California showed that vacuuming catches about 96 percent of adult fleas. A combination of controlled humidity, temperature, and vacuuming should eliminate fleas from an environment, and altering even one of these environmental factors may be enough to drastically lower and eliminate an infestation.
Old Oct 20, 2009 | 02:45 PM
TL black's Avatar
spray the car with some Raid.if you vac them up you will have a vacuum full of fleas.Raid or any kind of bug spray will work.
Old Oct 20, 2009 | 03:56 PM
Porkipine's Avatar
'07 NBP TL
Originally Posted by exceldetail
A little more info:
ty. good info here. i'll see what kind of solution i can come up. prob vacuum the car first and see how it goes.
true but i'm afraid its not safe to inhale the Raid.
Old Oct 20, 2009 | 06:29 PM
JulsV6's Avatar
8th Gear
I think she should set off a can of the flea fogger with windows up. give it an hour. open car doors to ventilate. Dont enter the car til car has fully vented out the fume. That should do the trick!
Old Oct 20, 2009 | 06:35 PM
Yvuru's Avatar
Just vacuum everything thoroughly at least 3 times.
Old Oct 20, 2009 | 06:50 PM
FirePR2002's Avatar
bringin lead
I agree with the vacuuming as others have stated, but also try diatomaceous earth (used in some pool filters). sprinkle the DE (available in quantity at Home Depot or online) over the entire carpet and let it sit a day, then vacuum it up. We use DE around the house for bugs and it works like a champ and is safe around humans and pets.
Old Oct 20, 2009 | 10:33 PM
SweetJazz's Avatar
2016 E350 Sport
I like this option. Those flea foggers work pretty well. I had an issue like this at my house a long time ago. In one of the rooms you could literally walk into the room and after 5-10 seconds you could see 10-15 fleas on your socks. A couple of foggers took care of them nicely with no residue to clean up.
Old Oct 21, 2009 | 05:53 AM
Former Sponsor
Thats another safe option! The DE dehydrates them, then simply vacuum.
Old Oct 23, 2009 | 12:59 AM
Porkipine's Avatar
'07 NBP TL
thanks guys. i'll let her kno.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
merc009
Oct 3, 2015 12:59 AM
