Remove Wax, Etc., To Apply Emblems?
Old Dec 15, 2006 | 02:25 PM
peter_bigblock's Avatar
C'mon, man! Row yer own.
I want to re-affix the "TSX" emblem to the trunklid of my car. Before I do that, I want to make sure all the wax, etc., is removed so I'm sticking the emblem to the clearcoat, right? What's the best product to use to remove all that wax, etc., without damaging the clear coat? Dawn? Rubbing alcohol and a microfiber? Other?
Thanks for your help!
Old Dec 15, 2006 | 11:48 PM
exceldetail's Avatar
Former Sponsor
Alcohol and a cotton ball..........done.
Old Dec 28, 2006 | 11:06 AM
PAINT4CARS's Avatar
Wax and Grease remover
First wash the area with hot soap and water. This will remove any water based contaminants that will not be removed by a solvent.
Next use a solvent based cleaner like Wax and Grease remover. Alcohol will work but you may need to do it several times to get the same quality adhesion as a professional wax and grease remover. Plus, a good solvent won't leave behind any residue. A good test is to splash some clean water on the area. Does it seem to "stick" to the surface? If it does then you are ready, wipe it off and proceed. If it just rolls or sheers off the car then you need to apply more solvent based cleaner.
-Mike
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
cycdaniel
Dec 17, 2019 10:58 AM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
