Protecting the paint from UV's
Hi all,
I just need some advice from u "the experts." I own a 2005 WDP TL. When I go to work, I leave my car outside and I was just wondering what to use to protect the paint. Also, I wold love to make the car this wet look. I know the white paint is never going to get this wet look but atleast close to it.
I'll have few days off of work, so that will be the perfect time to take care of the paint.
Thanks in advance.
Tim![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
BTW, this is my car
Thanks in advance.
Tim
BTW, this is my car
![](http://img118.imageshack.us/img118/6743/img5568gq1.jpg)
Former Sponsor
All you need to do (by the looks of it, looks pretty good from So Cal!) is crispen up the reflection a little. Clean the paint with a paint cleaner or light polish, then a good sealant like UPP or Optimums new OptiSeal.
OptiSeal toped with there Spray wax will give you UV protection.
When I get around to it, i will UPP one weekend, and OptiSeal the following.
I think most synthetic products have UV inhibitors and if the vehicle is frequently maintained you shouldn't have any problems. My product of choice is FS UPP and DG 111. Proper surface prep will bring out any color.
Let me see if I understood correct. One weekend I'll use UPP and by the next weekend the car will get dirty. I'll have to wash it and then I can use OptiSeal. That way I won't wash out the UPP coat?
Thanks guys.
Tim
Just dial 1911
1 Post
Originally Posted by tihomirbg
Thanks for your advice. I know u had this question so many times but where can I get UPP?
Thanks guys.
Tim![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
Thanks guys.
Tim
Originally Posted by joerockt
You can get UPP from right from Excel's store. Stuff is awesome. I'm doing a white BMW this weekend and its exactly what I'm going to use after a good polishing.
Just dial 1911
1 Post
I still have the Mothers Pre-wax cleaner/polish. Will that work before I can apply UPP?
Are you doing this by hand? Just a FYI . . . Hand polishing will create inconsistencies from panel to panel not to mention being time consuming and tiresome. Machine polishing is a much more effective process
Originally Posted by Hawhyen51
It's a mild polish that will clean and shine your paint. It will also remove oxidation, old wax buildup and other contaminants. If your paint is pretty much swirl free, I see no reason why it shouldn't work. If you do have surface defects (mild swirls, light scratches) I would suggest a more aggressive polish.
Are you doing this by hand? Just a FYI . . . Hand polishing will create inconsistencies from panel to panel not to mention being time consuming and tiresome. Machine polishing is a much more effective process ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
By "more aggressive" which one is in your mind?
If you're wondering what I use, I have on hand the FS Body Shop line, Optimum and PB polishes used with different polishing pads.
I know by hand is not the best way to do it, but hey I've been doing it that way many times.
The Old Grey Whistle Test
Clear Coats are two part systems (either a Urethane, or a good quality non-yellowing Polyurethane and an Epoxy) a solvent based urethane (a water-based clear coat is not yet available) is applied in two layers; it also contains ultra violet radiation (UVR) inhibitors. Clear coat is not armour plating but by adding UV blockers it provides a level of protection for the colour pigmentation of the base (colour) coat, but it must be protected, and the most durable protection is a polymer sealant.
Durability is really a very real concern for car owners today. With the increase in airborne pollution and other environmental factors, a car's finish is subject to serious damage. Acid rain; jet fuel fallout; industrial fallout; hard water, not to mention high acidic bird droppings; insect residue; tree sap all are very dangerous to a paint finish if not removed immediately.
Now, the OptiSeal, the car will get dirty before I can use the OptiSeal. Is it OK to wash the car? I won't wash the UPP way?
Also is this th OptiSeal your talking about?
http://www.prestostore.com/cgi-bin/s...520&recview=11
Former Sponsor
Why so much sealing? Your good to go with just the UPP?!
UPP probably didnt sit to well on the Mothers to begin with. I dont mind layering with like products but when you start adding different variations of products.....well, Its probably not very beneficial.
I think if you double coat your favorite product, your done!
And yes, thats the OptiSeal I have made reference to before.....I dont want to oversell anyone........If you have UPP, theres really no need to acquire any more products unless its to kill you curiosity.
Also, what do you recommend to use since Mothers is not that good to use before UPP?
Thanks for getting back to me so fast. I actually had people asking me, after the UPP, if this is the new Acura and I said this is 2005. They were like WOW for an 05 the paint looks very good. So now, after these 2 coats of UPP how much time should I wait before I use again?
Reapply 3-4 months, upkeep monthly with UPPS, and in between washes with a QD like DG AW. As far as using OptiSeal, I would use it as a stand alone product.
Former Sponsor
Thank you guys. You are the best. Next time I'll use just the Mothers Pre-wax cleaner/polish and then UPP with 2 coats and 24 hours between the coats.
When it is time to use the UPP, should I use Mothers Pre-wax cleaner/polish again or just UPP?
Pat, I'll need to buy just the UPPS to use once a month to keep the shine.
Tim
Tim
Former Sponsor
I would only use the UPP. Use the UPPS (If you want to) monthly to help maintain that UPP base. UPPS is a good stand alone, but I think the liquid version is slightly better. However, theres no better compliment to UPP then UPPS.
MrHeeltoe
20
02-23-2023 01:54 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
