Porter Cable Purchase
Old 04-22-2009, 12:24 PM
  #81
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Yea I dont know but im looking at the UDM for 110 shipped or best offer ill offer him 100 and see what happens
Old 04-22-2009, 01:18 PM
  #82
The Detailer
Denzil's Avatar
How's that PC coming along Noah? Put any more hours into it?
Old 04-22-2009, 01:29 PM
  #83
nf3d0149ab's Avatar
I haven't and I am beginning to worry that all the work I did with the clay will be null and void as a result.
To my understanding...I'm not supposed to polish in the sun right?
Old 04-22-2009, 01:32 PM
  #84
nf3d0149ab's Avatar
Another quick follow up question (or should I say questions )...should have written this down.
UFSE?
SIP?
1) I'm applying SIP as a polish right?
2) UFSE...forgot where that came in the lineup.
3) FS UPP is the sealant or topper? Applied last?
I am so
I should have written this stuff down.
Old 04-22-2009, 01:40 PM
  #85
zaino'd
jmkiang's Avatar
^ Hey how are you applying FS UPP? MF towel? On top of wax?
Old 04-22-2009, 01:48 PM
  #86
nf3d0149ab's Avatar
Honestly...I'm not sure.
I just started polishing using this SIP.
Haven't got there yet.
I think I am supposed the FS UPP with my PC.
Starting @ 4 and finishing @ 6...
Denzil is going to laugh when he reads this...
Looks like I didn't learn much except PC technique.
Old 04-22-2009, 02:54 PM
  #87
The Detailer
Denzil's Avatar
UFSE?
SIP?
I am so
UFSE = 3M Ultrafina SE (finishing polish)
SIP = Menzerna Super Intensive Polish (medium polish)
1) Yes, SIP is your first step and will be followed by UFSE as your last polishing step.
2) See above.
3) FS UPP is your sealant and LSP (last step product aka protection). You will apply it with a yellow foam applicator that you can get locally from AutoZone or Kragen. You could apply it via PC at speed 2 but you don't have the right foam pad (you need the red foam pad from Patrick).
On a similar note, sealants are always before wax if you decide to layer your LSP's.
Old 04-22-2009, 04:56 PM
  #88
nf3d0149ab's Avatar
Thanks!
BTW...we are going out tonight for beers if you can join us...you should!
Check the Bay Area thread for info.
Old 04-28-2009, 04:10 AM
  #89
nf3d0149ab's Avatar
Oh ok.
Was working on my first mini detail.
I got to say...dayum that's some hard work.
My hand was numb for like 20 minutes.
I guess you get used to it after a while...
Couple of follow ups...
1)
I have some stuff that's not lifting with White Lake Country Polishing Pad + SIP.
Can I use Yellow Lake Country Cutting Pad + UFSE? Is that an okay next step..it's what I got?
2)
I need a red pad to apply FSUPP?
3)
Should I look into the Opti-Seal product now for going forward since I used an independent polish & sealant?
Old 04-28-2009, 04:23 AM
  #90
nf3d0149ab's Avatar
^ EDIT:
I meant Optimum Poli-Seal.
Old 04-28-2009, 07:36 AM
  #91
vinnier6's Avatar
^ EDIT:
get some grey pads, thats what i use to apply upp, i use speed 2 and i can whip out the car in like 15 minutes....
everyone should have a bottle of poliseal, this is a good all around product, it is considered an all in one polish, cleaner, sealant, but it doesnt have much protection or correction ability in it, but it sure does clean up the paint really nice so you have a nice clean base to apply upp....i use the grey pad with poliseal on speed 3-4 and work it in, it dissapears very quick, so this will be a quick pass too...
i dont use sip, but from what i understand, it takes a while to work in, speed 6 here and the white or orange pad....
Old 04-28-2009, 08:46 AM
  #92
zaino'd
jmkiang's Avatar
When you guys refer to FSUPP, its the one in the spray bottle right? Are you just misting the grey pad to apply?
From your description of Poli-Seal, it sounds like an AIO... any difference between this and Klasse AIO or ZAIO?
After creating a nice base using one of the above methods, it goes sealant, then wax right? Where does the UPP fall?
Old 04-28-2009, 11:47 AM
  #93
vinnier6's Avatar
4 star ultimate paint protection...it doenst come in a spray bottle, that would be the 4 star ultimate spray wax...do not confuse these two products....
Old 04-28-2009, 11:55 AM
  #94
zaino'd
jmkiang's Avatar
^ I have the same stuff in a spray bottle... bought it from Patrick.
Four Star Ultimate Paint Protectant Spray (Limited qty, discontinued) $ 14.89
Quantity: 1
Item total: $ 14.89
Guess its old school!
Old 04-28-2009, 12:12 PM
  #95
Former Sponsor
exceldetail's Avatar
I dont know why they discountinued that spray. That stuff was better then what they have now......
Old 04-28-2009, 12:19 PM
  #96
zaino'd
jmkiang's Avatar
^ Apply on a foam pad or use the grey pad on a PC?
Old 04-28-2009, 12:30 PM
  #97
Sǝxy Timǝ in my
smsTL's Avatar
I need some of those...
Old 04-28-2009, 12:39 PM
  #98
The Detailer
Denzil's Avatar
Oh ok.
1)
2)
3)
1) UFSE is your finishing polish Noah. You'll probably want to use the yellow pad and SIP for your strongest combination available to you.
2) You don't really need a red pad for UPP but I like to use it. You can use a yellow foam applicator by hand or if you want to do it via machine, you can use that black pad for final finishing and LSP application. Just be sure you use separate black pads.
3) Opti-Seal is a pretty nice product and that small bottle goes a really long way once you get the application method down. You can spread that stuff pretty far!
Old 04-28-2009, 12:57 PM
  #99
nf3d0149ab's Avatar
Ok....yeah I have a couple of black pads.
I was applying it by hand.
You know what though...I should go snap some pictures.
Because I was trying to lift some marks on my door panel...and nada.
So that means I need to go deeper right? SIP + Yellow Cutting Pad?
Or keep hitting it with SIP and White Polish. Pad?
*Note...SIP is the only polish I have right now.
If I polished an area yesterday that I didn't seal...which I know is bad.
What can I do...to get back into that area safely and continue working today?
Old 04-28-2009, 01:00 PM
  #100
nf3d0149ab's Avatar
I keep reading about Poli-Seal which is why I was thinking about picking it up.
Seems to be a really popular "all in one" go to product.
Good for amateurs like myself.
Yeah what I have is in a bottle and the consistency is almost milky...
Old 04-28-2009, 03:12 PM
  #101
The Detailer
Denzil's Avatar
Well if SIP and white isn't doing much, you could try jumping up to SIP and yellow.
Just QD the area you didn't seal and have at it again.
Old 04-28-2009, 03:14 PM
  #102
vinnier6's Avatar
becareful with sip and pads, i was told to use one pad agressiveness down from what you think you need...i cant imagine needing anything more then an orange pad....i guess it really depends on what the condition of the paint your working on is....
Old 04-28-2009, 03:47 PM
  #103
nf3d0149ab's Avatar
Ok...here is a mini update.
I re-washed the area I didn't seal since I had already mixed ONRW in the sprayer already.
Went back over the hood which I bought used and had the most damage.
Can't seem to lift the scratches with SIP + Yellow Cutting Pad.
Am I doing something wrong?
I apply @ 4 and finish @ 6
The trunk is coming out nice...that's just SIP + White Pad
Old 04-28-2009, 04:14 PM
  #104
zaino'd
jmkiang's Avatar
OP, are you "spritzing" the pads before using them? Or do you just apply the product dry and start working?
Old 04-28-2009, 04:15 PM
  #105
B A N N E D
jaysizzlecity's Avatar
Nice work......
Old 04-28-2009, 04:21 PM
  #106
nf3d0149ab's Avatar
Applying the product directly to pad @ 3,6,9,12 o'clock positions in dime size amounts.
Originally Posted by jaysizzlecity
Nice work......
Thanks man...trying.
Old 04-28-2009, 04:46 PM
  #107
nf3d0149ab's Avatar
Couple of more problem areas...
Can't figure out what's going on here...
The car was previously rear-ended...maybe paint over spray?
What do you guys think?
Also...where I removed my mudguards...
Old 04-28-2009, 04:58 PM
  #108
nf3d0149ab's Avatar
I also...have this...on the other side in almost the same spot.
So looks like a shitty ass cover up paint job!!!
Old 04-28-2009, 05:52 PM
  #109
vinnier6's Avatar
i dont always mist my pads before i start working, its not necessary...as long as you prime the pad correctly you will be fine....
Old 04-28-2009, 07:12 PM
  #110
nf3d0149ab's Avatar
What would you "spritz" the pad with?
Old 04-28-2009, 08:32 PM
  #111
zaino'd
jmkiang's Avatar
QD? Haha I dunno
How does one prime a pad?
Old 04-28-2009, 08:39 PM
  #112
vinnier6's Avatar
QD? Haha I dunno
with the correct amount of polish to lubricate the pad...that is the whole idea...
Old 04-28-2009, 08:41 PM
  #113
vinnier6's Avatar
you can also use just plain ole water...i do use the quick detail spray on pads that look older, but if i use a new pad i just prime it with polish, meaning i use a little more then usual, and spread it evenly over the pad....just enough so your not running a dry pad on your paint...
Old 04-28-2009, 09:00 PM
  #114
nf3d0149ab's Avatar
Red face Completion...for now
A couple after pics from my first little detail.
Def. was a learning experience and I'm not entirely happy with it because I didn't everything I needed to.
Started getting lazy...
I really needed to go back and re-do my hood because I couldn't lift the scratches.
But that can be for another time and I plan on getting it re-cleared so...
Anyways...not too bad for a detailing virgin.
I can clearly tell where my car was re-painted and see how bad the paint job was...!
Old 04-28-2009, 09:48 PM
  #115
zaino'd
jmkiang's Avatar
nice!
Old 04-28-2009, 09:54 PM
  #116
The Detailer
Denzil's Avatar
Looks pretty good Noah but let's see some sun shots! That'll truly show how good of a job you did, hehe.
Old 04-28-2009, 09:55 PM
  #117
nf3d0149ab's Avatar
nice!
Thanks man!
Shh...let me feel good for one moment!
Probably doesn't look as good in the full sun!
Old 04-28-2009, 10:00 PM
  #118
nf3d0149ab's Avatar
I got too lazy to wash all my wheels...
Only finished two...lol
I'm freaking tired...detailing is good excercise!
Old 04-28-2009, 10:05 PM
  #119
nf3d0149ab's Avatar
Since I already sealed it with FSUPP...I guess that means I'm done now...
Is that right?
Well I wash once a week so will I just wash with ONRW and dry with Optimum spray wax to maintain?
And then once a month apply FSUPP?
Old 04-29-2009, 01:19 AM
  #120
The Detailer
Denzil's Avatar
Is that right?
Yep, yep and yep!
Quick Reply: Porter Cable Purchase
