Polishing windows
Old May 20, 2007 | 11:21 PM
syee99's Avatar
Polishing windows
Anyone used their PC to polish their windows? I've had this done once at a detailing place to remove "water spots" on my windshield. What do they use to polish? I'm just trying to get rid of what looks like water stains on the glass. Now that I got my PC, I want to do it myself rather than pay them $30 to do it.
Old May 21, 2007 | 03:32 AM
TOGWT's Avatar
The Old Grey Whistle Test
Polishing Glass (Stage Two Surface Corrosion):
Once the glass surface has been washed and cleaned (detailers clay) any minor imperfections can be removed with an abrasive glass polish (Autoglym Car Class Polish or DP High Performance Glass Restorer) This thick citrus-based cream safely pulls contaminants out of the glass, including alkaline mineral deposits, and then smoothes out etched glass (http://www.autogeek.org)
Be aware the some imperfections cannot be removed and you may have to replace it. If you can catch your fingernail in the scratch 0.4 Mil (0 .004 –inch deep) you should consult a professional glass repair / replacement company.
A replacement windscreen can sometimes be claimed on an insurance policy without loss of no-claim bonus, dependant upon coverage (check first with insurance company).Some windscreen ‘glass’ is actually a plastic resin and will scratch easily, consult your dealer to find out what material was used for the OEM windshield.
Methodology (b):• Clean glass to remove dirt, dust or road grime from surfaces (also see note 1)
•Apply clay (Magic Clay®) and lubricant solution (WooliteTM / Water 5:1) onto the glass surface (Do not apply to plastic as dulling may occur.)
•Apply a quarter (coin) size amount of Autoglym Car Glass Polish™ or Iz Einzette Glas Polish to a damp cutting / polishing foam pad (LC Orange or White) attached to a Porter Cable HS rotary polisher set at speed 1200 rpm.
•Heat caused by abrasive polishing can soften and damage glass; foam pad and product used must minimize heat build-up. Since glass is a poor heat conductor any friction heat built up from polishing must be kept to a minimum by using sufficient product and regular misting of both the polishing pad and glass surface with water.
•Apply to half of the windshield, polishing first in an up and down motion then in a left-to-right motion and then repeat on the other side, proceed to other glass surfaces.
•Go over the glass several times in each direction, glass will polish virtually residue free.
•Wipe off any residue, and polish with a clean dry 100% cotton Micro fibre cloth.
•Inspect glass for clarity and smoothness. Repeat if necessary.
•If the glass has PPG Industries Optech clear coating a more aggressive polish may be required
Alternative products / methods:
a) Apply Zaino Z-12 with a damp cotton cloth to cool glass, apply to small sections at a time and allow to completely dry, buffing with a clean dry cotton towel. If there is any smearing or residue left just use Stoner’s Invisible Glass or any good quality glass cleaner to remove excess residue.
b) Janvil Scratch Remover (JV-326 / Glass Renew JV-325) - http://www.janvil.com/glass_restore.htm
c) Glass Technology Inc - http://www.gtglass.com/scratchremoval.htm
Alternative pads- these 4-inch ‘Metal Polishing Pads’ are made of course, 600 grit nylon (Scotchbrite®) and are designed for hard / rough surfaces like aluminium diamond plate, pitted aluminium, chrome, and glass. http://topoftheline.com
Old May 21, 2007 | 12:51 PM
jwclements1's Avatar
I just bought some glass polish from griots garage and used an orange pad. It removed all the water spots and made the glass sheet to prevent more spots from forming.
Old May 21, 2007 | 04:42 PM
egprelude's Avatar
You can probably use any type of polish for lihgt swirl removal. IT should work pretty well with a good pad on the PC.
Old Jul 12, 2007 | 07:36 PM
loojoohnnyl's Avatar
i just use windex made for cars
Old Jul 13, 2007 | 02:24 PM
alucardx's Avatar
he's talking about polishing, not simply cleaning it. and i still wouldn't use Windex anything on my car. Stoner's IG or DG Glass cleaner all the way.
Old Jul 14, 2007 | 12:15 AM
syee99's Avatar
haha...yep...Windex and a terry cloth towel and a lot of elbow grease was the first thing I did. Didn't fix the problem which was why I had to resort to the local detail shop with their PC and glass polish.
Old Jul 14, 2007 | 12:55 AM
csmeance's Avatar
I clayed my car, and when i clayed it, it clayed the windows to. Got rid of the waterspots and such and then followed up with rainx
Old Jul 14, 2007 | 01:45 PM
stogie1020's Avatar
Needs more Lemon Pledge
Did you use QD for a lube on the glass too, or something else?
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
