Polish
Polish if you feel you need to brighten it up, then seal it. NXT has some cleaner which will help to clean the surface " a little." BUt nothing is better for a sealant, then a nice clean sterile surface.....I would at a minimum, use a paint cleaner.
Originally Posted by jeeper31
Paint cleaner?
1. Wash with a good CAR wash (NO DAWN)
2. Clay
3. paint cleaner (I have Poorboys Pro polish)
4. seal with the NXT
Should get you looking good and protecting the finish.
Good luck!!
Car is a few days old, can I just wax or should I polish first? I will be using the Meguiars NXT Tech Wax.
Polish cleans the paint by removing oxidation and minor imperfections and makes the surface ready to accept a sealant/wax. You mentioned using NXT, you can use Megs #81 Hand Polish or a cleaner like Klasse AIO prior to application of NXT. Of course the choice is yours.
I would claybar it first. If you examine it closely you'll find remenants of the plastic panel adhesive on your paint (at least I did). The plastic panels are on the car during shipment to protect it. Once the car is delivered the dealer should pull the plastic protectant off and clean the surface. Still, mine had remenants on it. Claying should take that stuff off.
Should you decide to polish, I would, as everyone (almost) suggested, use a clay bar to remove surface contamination i.e. brake dust, road film, bug splatter, etc. You can use a QD or a soap/water mix to act as a lubricant for the clay. More info can be found at this thread by Exceldetail called Proper Claying Technique or Autopia's How To Library. Once this is done you will feel a difference between a clayed surface and one that isn't. Apply the polish of your choice and then final application on a selant/wax. Go for it, it's all good. You may not want to drive your TL after you get done.
BoricuaTL
Apr 8, 2016 01:08 PM
vtec314
Nov 7, 2015 08:20 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
