PC7424 Backing Plates
WIP-Work in Progress
I have the 6in backing plate that came with my PC when I bought it. I'm looking at buying a 4" or a 6.5" pad.
Can someone explain what are the benefits of matching the backing plate with those pads?
Or can I just get buy using the 6" backing plate with the 4" pad?
I want to get a 4" yellow pad to see if I can get some scratches out that I wasn't able to do with the 5.5 orange pad matched with OP Hyper Compound. Trying to justify spending more money for a backing plate and another pad.
Hope this helps answer you question.
George
Along with Georges comments, the 4" pads offer a more concentrated work area, zero fatigue on the machine. You now have all the weight of the machine spread out over nearly 1/3 less area as compared to a 5.5". Careful while polishing with 4" pads, especially yellow. Keep your speeds at a safe level, an do not let the machine polish in one area too long.
Thanks for the responses, couple more questions.
If I get the 6.5" Yellow pad then I should be okay with the 6" backing plate correct? But since it's a bigger pad I wouldn't get the concentrated efforts compared to the 4" right?
Keep in mind, this is valid only for random orbital buffers, the opposite is true for rotary buffer since the outer edges will spin the fastest.
If you have any other other questions, let us know.
George
On a similar question, what are the risk of using a 6.5" pad on the 5" backing plate. Would it sling stuff out when using it on PCXP speed 4 or more as the extra 1/2" pad which extends beyond the plate may nothave enought presure?
I currently have a 5" BP which works with my 5.5" pads. However I have been wanting to check whether the 6.5" pads will be more suitable for applying LSP products. without wanting to spring for a new BP for experimenting, I want to try the 6.5" PAD on 5" BP.
When using a 6.5" pad with 5" BP, your pad is not supported. With centrifugal force, there is fatigue to the pad on the outside edge. Not good for pads.......
Match pads with BP's................
Patrick thanks for you response.
The 5.5" setup seems sufficient by iteself for me. so before clunking (I mean investing) $ into 6.5" setup, could you advise if there any significant benefit in applying LSP via 6.5" blue (w/proper BP) over a 5.5" Blue pads (which work just fine). The only other use for 6" BP I can think off is PFW which I have not considered using yet as I think I can handle some of the swirls I have with an orange pad/SIPS combo.
The only real differences between the two setup is concentrated work areas. LSP's with 6.5 are fine provided they accommodate the body styles of the surfaces your working on. 5.5"s and 4"s are real nice when applying products between emblems and wheel wells, below mirrors, door handles and window frames etc.....
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
darksky
09-05-2015 03:11 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
