My plan of attack, what do you think? Which pads should I use?
Not a Registered User
Spring is here, time to kick off the new season with a complete detail. I will be attempting claying and swirl removal for the first time. This is what I plan on doing, what do you think?
1 -Wash w/ dishwash detergent
2 -Claybar with lube
3 -Wash w/ carwash soap
4 -Four Star Swirl Mark Remover
5 -Four Star Polish
6 -Four Sar UPP
That's it. Swirls are about moderate, I polished and waxed numerous times throughout the year using Blackfire products.
Would any claybar suffice given my car's in decent shape?
What pads should I use for steps 4-6? (PC 7424)
5 -Four Star Polish
6 -Four Sar UPP
if your going to clay the car and polish the car, i dont see a need to wash with dishsoap....
i havent done my car yet, but i was thinking i would start light first, in your case, i would think you would want to start with the polish first, then if you dont get the desired results go to the swirl remover....no sense in using an extra step if you dont need to...know what i mean...
5 -Four Star Polish
6 -Four Sar UPP
5 -Four Star Polish
6 -Four Sar UPP
What pads should I use for steps 4-6? (PC7424)
I am confused, i thought the whole point of claying your car was to start a new, by taking out any previous wax that was in the car. and how you do that was by washing it with dish soap.
Is it a good idea to clay bar without washing the car with dish soap? is the a positive or a negative?
Claying removes contaminats and it may or may not remove all of the wax/sealant.
Therei s no real need to wash with Dawn unless your applying a sealant right after claying or or not claying at all. Dawn will help remove residual wax and oils gicing the sealant a good surface to bond to.
BUT... in reality if your going to do it right .. polish the car out .. it will remove the old wax/oils and QD residue. if not .. at least use a cleaner like Klasse AIO or PoliSeal.
Alternate is to wipe the car down after claying with a 50/50 solution of IPA & water.
I do not mean to thread jack i just think this would further the instruction and would help the OP figure out this process as well as mine.
This is what i was planning on doing for my 07 nhb.
#1 - Wash Car with Dishsoap
#2 - Clay Bar w/ lube
#3 - Wash Car w/ car wash soap (zaino brand)
#4 - Use Poorboy's SSR1 & SSR2 for some swirls and scratches
#5 - Use Zaino-2
#6 - Use Zaino 5
#7 - Use Zaino-6
#8 - Lay down and have a drink
Now the dish soap part after searching here, I will no longer due. Can anyone recommend me a product to help me prep the car, because I feel the Zaino Soap is not strong enough.
Am I missing anything? Thanks for any advice.
And to the OP i probably would not chance it with dish soap
#5 - Use Zaino-2
#6 - Use Zaino 5
#7 - Use Zaino-6
#5 - Use Zaino-2
#6 - Use Zaino 5
#7 - Use Zaino-6
#5 - Use Zaino-2
#6 - Use Zaino 5
#7 - Use Zaino-6
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
