Meguiar's 3 Step Deep Crystal System
Anyone use Meguiar's Deep Crystal Deep Cleaner and Polish? I got a Black TSX with some minor swirl marks. Or should I just clay then use the Deel Cyrstal Polish? Or does it matter???? Is claying better/worse/same as using a paint cleaner like Deep Cleaner? Since this is a new car, I'm leaning towards claying then polishing.
Any thoughts????
Any thoughts????
Re: Meguiar's 3 Step Deep Crystal System
Imagine your car finish is a VERY small landscape with boulders and gullies or river beds ... claying pulls out the boulders, and polishing rounds over the edges of the gullies (or even flattens this micro-landscape). Clay removes objects that rise above the level of the surrounding clear coat. It's great for removing tar, sap, adhesives on delivery, paint splatters, minerals left by water, and other common things that sit on top of the finish. Done correctly, it's easy, fast, and low risk to the finish. And your car will feel glassy smooth afterwards.
Polishing is the only way to physically remove swirls -- you round over the edge of the scratch groove, or even remove enough finish that everything is completely level. But it is a potentially destructive process, has some risk depending on abrasiveness, and you don't want to use any more abrasive polish than necessary. You can hide the swirls with many waxes, but they'll come back in a few weeks as the wax wears off.
Since you're curious, try claying and experience what it does and doesn't do. I use Clay Magic brand since it was available locally (Pep Boys), inexpensive ($10), and was well regarded by experienced detailers. It's a very handy tool for car care.
I love using the Clay Bar! For those who haven't used a Clay Bar, but are thinking of using one, be sure to use a lubricant. Regular car wash detergent/soap works very well for me as a lube. It's amazing what a clay bar still picks up AFTER you do a regular wash.
Sorry, I don't know about Maquire's product. I currently have Turtle Wax 2000--which isn't wax--but it doesn't seem to last very long. I hope to use it up soon and then try something else.
Thanks for the responses! Here's my plan:
1. Clay
2. Polish using Maguiar's Step 2 Deep Crystal Polish
3. Wax
Brad - I too use Turtle Wax Finish 2001. It's ok but I prefer a wet look to my car since it's black. But I also like the polymer's protection properties since the car is outside 10+ hours on workdays. Maybe when Maguiar's new NXT wax comes out, I'll try that. It's either that or putting on a layer of carnuba wax on top of the Finish 2001. We'll see....
1. Clay
3. Wax
Here's how I clean my Boxster:
1. Wash with Meguiar's Deep Crystal Car Wash... soap and bucket. Always wash first with lots of high-pressure water.
2. Clay bar with Mother's quick detailing spray as a lube or Meguiar's Quik Clay Detailing System
3. Clean... Meguiar's Deep Crystal Paint Cleaner . This is still necessary, it gets out the nasty oxidation and so on.
4. Polish... Meguiar's Deep Crystal Polish. For that deep shine!
5. Wax: Gold Class Clear Coat Car Wax. Nice, and a heck of a lot cheaper than Zymol (which is great, but too much for my leased car).
6. Wax again.
Use only 100% cotton towels/diapers. I also use a few good synthetic chamois for drying & buffing.
Pick your brand, but I stay away from Turtlwax & Armorall. Mothers and Meguiars are good store brands, with Zymol being one of the great top-shelf brands. I use their rubber treatment on the seals around my convertible top and windows.
For cleaning rims, I recommend P21S wheel cleaner... good stuff.
6. Wax again.
Not an Ashtray
1. Clay
3. Wax
1. Clay
3. Wax
I wouldn't do this if I were you. Meguir's polish is actually fairly harsh, and you could wind up causing swirls or little micro-scratches. A better option, might be to go with the Klasse "twins" (All-in-one and sealent glaze).
Here's the link: http://www.acura-tsx.com/forums/show...&threadid=6154
I don't recall seeing the Klasse at Pep Boys the other day. I did see Mother's products. I want something that I can get at my local Pep Boys or Kragen.
There's another thread in which a poster recommended Meguiar's cleaner wax. http://www.acura-tsx.com/forums/show...9274#post89274
Would this be a better alternative than using the polish???
Not an Ashtray
Consumer Reports tested the Meguirs products and found that they caused hazing and small scratches. Now, the products may APPEAR to remove swirls, because they temporarily fill in scratches and other imperfections with wax. If they are actually removing swirls, they must be very abrasive and are probably not suitable for use on a new car.
Looking at this site, it's got nothing but rave reviews. http://www.carreview.com/pscParts/Ca...7_2906crx.aspx
Do you have a link to the Consumer Report or did you read it in their magazine???
Not an Ashtray
You can go to www.consumerreports.org, but you'll only be able to access all the reviews if you are a subscriber.
There are, btw, only two ways to remove swirls: You can use something so abbrassive that it cuts the finish, or you can use something that is fluid it enough that it fills in (and hides) imperfections.
If you want to see reviews of all these products, go to www.autopia.org. That is the best source for information on waxes and other detailing products.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
