Halogen Lighting, What Wattage?
Hey guys,
Anyway weather’s getting decent here in Toronto, and I have posted local ad’s into automotive detailing and paint correction, I have received a few inquires and have a customer dropping by Saturday morning with a 2001 Honda Accord (black) that would like ‘light’ swirl removal done, or at least he calls it that.
Anyway, I was wondering would a 500W twin head halogen work light, mounted on a tripod be good enough to illuminate those scratch’s and swirls, or would I be better off with a 1000W lighting?
I use a 500 watt twin head, with a tripod and it works great for me. I wax/polish in the garage.
You should look at the rated amperage on it as well. Don't want any breakers tripping.
I have a dual head ( each 500 w ) and it does the job when I have to work in the garage.
And they do get hot ... kind of nice this time of year to warm the area a bit.
When buying one really check the stand. I have one with 5 feet on it and its absolute crap. Hard to open & close and the tubes on the vertical shaft are screwed together using plastic inserts so after a few uses its unstable.
If you can look at one set up before you buy. I'm looking for a used burned out one to swap my top to.
I'm always scred the UDM cord will catch on it and I'll pull it over on the car. Right now I bungie it so it won't.
2016 E350 Sport
Originally Posted by exceldetail
The higher the wattage, the HOTTER those bastards get! And they do generate some heat!! So select carefully. I won a twin 500/1000 watter.
mada51589
05-03-2022 08:54 PM
Greengecko
09-16-2015 08:19 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
