Detailing tip of the week
Old Mar 3, 2010 | 02:40 PM
SWGUY's Avatar
would it be a good thread?
anyone can put there tips for others to learn....
Old Mar 24, 2010 | 12:53 PM
SWGUY's Avatar
Detailing tip of the week : what to do first when detailing your car (interior, engine, wheels and last exterior)
Old Mar 24, 2010 | 02:54 PM
exceldetail's Avatar
Former Sponsor
I do wheels first........
Old Mar 24, 2010 | 03:09 PM
n0rm's Avatar
I ♡ PEK PEK
OP, any affiliation to Smartwax or CG?
Old Mar 24, 2010 | 04:30 PM
mrclrider's Avatar
Wheels first for me too.
Old Mar 25, 2010 | 12:09 AM
Steen27's Avatar
really? why wheels first? I have always done wheels last...
Old Mar 25, 2010 | 04:43 AM
TOGWT's Avatar
The Old Grey Whistle Test
When you wash the car, remember to use open cell wash media, something that can hold on to the dirt that is on the car without dragging it against the paint surface. Detail the interior first; avoiding wet/dirty footwear on the carpets. Ensure there is sufficient high lubricity car wash concentrate in your GritGuard bucket.
As you wash, start at the top of the vehicle, and work your way down. The top is the cleanest; the bottom has the most road dirt / grime; wheels last. After every individual pass washing, rinse your mitt with your hose to dislodge the dirt and grime that you just removed from the car, before putting it back in the bucket for more soap
Old Mar 25, 2010 | 07:32 AM
Former Sponsor
Cuz I hate interiors. Exterior is instant gratification. Wheel cleaning inevitable relies on brushes and/or spray cleaning products. Brushes often have the tendency to make a larger mess, lol. And then you have that spray wafting in the air. Just makes sense to get the dirty wheels out of the way first.
Old Mar 25, 2010 | 08:39 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Interesting, I always do my wheels last, but I have to be super careful, maybe I'll try the wheels first next time
Old Mar 25, 2010 | 12:59 PM
Steen27's Avatar
Interesting.... I should try it next time...
Good Luck with WestCoastDetailSupply.com - You've been a great supporter of detailing with care and always give sound advice and I hope the new business does well.
Old Mar 25, 2010 | 04:19 PM
Former Sponsor
Thank you James!
Old Mar 25, 2010 | 06:54 PM
JS + XES's Avatar
I drive a Subata.
I always do rims first......
Old Mar 25, 2010 | 07:24 PM
karbotsx2's Avatar
I do wheels last.
Old Mar 25, 2010 | 09:09 PM
Jesstzn's Avatar
Customer cars they & the tires are done first .. on my own car they are last , I use a separate mitt and the last of my wash water that way even with a grit guard there is less chance of stirring up something and it getting on the paint.
Old Mar 25, 2010 | 09:13 PM
SOCAL BRO!!!'s Avatar
got brohoes?
Bro, you gotta do wheels first b/c they tend to be hella dirtier than the rest of the car. ~clean wheels ~rinse car ~wash car ~dry car ~clay bar car ~polish car ~wax car ~interior ~apply wheel dressing
Old Mar 25, 2010 | 09:56 PM
SweetJazz's Avatar
2016 E350 Sport
Wheels First.
Old Mar 25, 2010 | 11:24 PM
PortlandRL's Avatar
When polishing with a rotary and you want to locate holograms before finishing down, use either an LED flashlight or take a picture with the camera on flash. Obviously if the sun is available, use that.
Old Mar 26, 2010 | 12:22 AM
SpiderX1016's Avatar
I do everything top to bottom. That includes wheels last.
Old Mar 26, 2010 | 04:04 AM
TOGWT's Avatar
To avoid friction of the vinyl rear window material of a roaster or convertible, place a 100% cotton micro fibre towel, front and back, before putting the top down. Do not use terry cloth towelling, as this is abrasive and will cause scratches.
(Exceldetail- glad to see you up and running again :0 )
Old Mar 26, 2010 | 08:19 AM
Former Sponsor
Thanks Jon!
Old Mar 26, 2010 | 10:28 PM
ANC297's Avatar
Bonki' Ehrite!
Wheels first for me as well. I used to do them last, and then the quarter panels would get all wet again after drying.
Old Mar 28, 2010 | 01:31 AM
triggerman's Avatar
Wheels first most of the time, Sometimes if I have a very dirty interior I will start with the interior so it has more time to dry after shampoo.
Old Mar 29, 2010 | 01:11 AM
dtownz_thrillah's Avatar
5th Gear
I detail interior first then top to bottom on the exterior. Then sometimes I get bored and take off my wheels and clean the barrels.
Old Mar 29, 2010 | 03:23 AM
TOGWT's Avatar
Two of the Cardinal Rules of Detailing
1. It cannot be emphasized enough ‘Apply products very sparingly’ Ease of product removal is inversely proportional to the amount used
2. Always choose the least intrusive product, it is preferable to polish 2-3 times to restore the paint film surface than to use an unnecessarily abrasive machine polish / foam pad combination.
Old Mar 29, 2010 | 06:16 AM
TOGWT's Avatar
Limiting scratches when drying a black car
I always dry the car using a surfactant type (ONR) detail spray (8oz / gallon) and a waffle weave micro fibre towel. Why? A surfactant encapsulates any dirt and will provide lubricity to the paint's surface as you blot the paint to minimize adding imperfections. This method will safely remove any water spots that might occur
This drying technique is excellent for black cars (the ones with ‘soft’ single stage paint that show every surface mark) but look so good when they are properly detailed. This process never includes scrubbing, rubbing or applying any pressure whatsoever. The only time that pressure needs to be applied to a paint surface is when you are polishing.
Old Mar 29, 2010 | 03:55 PM
SWGUY's Avatar
why interior first... want to avoid bringing wet shoes back inside the car...
Old Mar 30, 2010 | 03:16 AM
TOGWT's Avatar
Pre-test Spot Procedures
After checking the pH value and MSDS of the cleaner, apply several drops of the selected cleaning solution in an inconspicuous area and rub gently with a clean, white micro fibre towel. Do not over wet. Use small amounts of the product and blot frequently, do not rub or use too much pressure. Works from outer edge of the spot towards the centre to prevent rings
Do not use the product if it adversely changes your fabric's colour or texture.
Old Apr 1, 2010 | 01:21 PM
SWGUY's Avatar
Detailing tip of the week: when fully detailing the exterior of your car (wash,clay,seal,glaze,wax) you should be using 6-12 towels min. preferable double sided microfiber towels with silk trimming -
Old Apr 1, 2010 | 01:30 PM
Bearcat94's Avatar
AZ Community Team
Inside Front Windsheild VS Dash protectant? Which first?
AND how do you keep dash protectant off the winsheild OR keep from wiping protectant off of the dash while cleaning the windsheild?
Old Apr 1, 2010 | 01:49 PM
n0rm's Avatar
I ♡ PEK PEK
I do dash protectant first then windshield using a glass wand.
Old Apr 8, 2010 | 05:25 PM
SWGUY's Avatar
Detailing tip of the week " when applying dressing to your interior vinyl apply gently as if you did with wax in a circular motion but to reduce it from attracting dust after applying the dressing, simply wipe down with a microfiber towel to give it a fresh look"
Old Apr 8, 2010 | 06:08 PM
mrclrider's Avatar
A short nap microfiber soaked in ONR wash dilution rung out well will clean windows really well, a 2nd dry short nap microfiber to buff afterward will guarantee streak free results.
Old Apr 8, 2010 | 06:10 PM
Jesstzn's Avatar
Whats the ratio? I have the QD and the Clay ratio..
Old Apr 8, 2010 | 08:50 PM
mrclrider's Avatar
My little bucket for cleaning windows is just at regular wash dilution, 1oz per 2 gallons. Its about 1/4 oz for me because my little container I keep my short napped microfiber in is only half a gallon. Don't see why you couldn't have it mixed at QD strength though.
Old Apr 14, 2010 | 03:00 PM
SWGUY's Avatar
detailing tip of the week: "for those that do car shows or just simply want to use no water to clean your rim & tires on the spot, we have a solution...use any citrus base product like carpet cleaner or ------- blended with water on the rim & tire, wipe off with a microfiber towel to a perfect clean surface" app...ly more if needed. this process is good on any type of finishes.
Old Apr 14, 2010 | 03:27 PM
Jesstzn's Avatar
Won't the solution remove any wax on the wheels?
Old Apr 14, 2010 | 09:49 PM
trumanb24's Avatar
once a year (or whenever I rotate the tires) I powerwash the wheels while they are off the car
Old Apr 18, 2010 | 10:00 PM
I also like to take the car around the block after washing the car and then take a towel and dry off all the little droplets. Some times I use a quick detailer if it dried and streaked.
youngTL
5G TLX Performance Parts & Modifications
55
May 23, 2020 07:39 AM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
mugen_kid
Nov 13, 2015 10:38 PM
IIDXholic
Oct 8, 2015 07:53 AM
