Debadging
Old Oct 25, 2005 | 07:32 PM
BATTLESHIP's Avatar
Debadging
Hello ALL:
This is my first new thread post... I have a question about debadging. A friend of mine told me that in order to do this, all you need to do is take dental floss, wrap it around the badge, and basially "pull" or cut the sticky foam with the floss. Then follow up with rubbing alcohol to take the rest of the left-over adhesive residue off.
IS THIS TRUE? Can I go out right now, get some rubbing alcohol from the store, and start and finish the job tonight?
Thanks for the help!
Old Oct 25, 2005 | 07:43 PM
TOGWT's Avatar
The Old Grey Whistle Test
If the badge is attached with double sided tape that removal method plus soaking the badge with alcohol should work. Note: some bages have a 'pin' system and when they are removed there are two small holes in the bodywork
Old Oct 25, 2005 | 11:56 PM
joerockt's Avatar
Just dial 1911
If you have a heat gun, use that too, or just let it sit out in the sun for a few hours...
Old Oct 26, 2005 | 06:28 AM
VB87's Avatar
Some people also use GooGone. I think you can debadge everything but the A emblem.
Old Oct 26, 2005 | 10:39 AM
gsclifton's Avatar
ABP TSX
Debadging
Old Oct 26, 2005 | 12:08 PM
lothian110's Avatar
isnt it horrible to put alcohol on ure paint?
just get a heat gun.. u can prob pick one up for 20 bucks at home depot...
heat up the badge real nice.. then use the dental floss to get it off once its warm..
should even leave any residue...
like they said.. make sure its just double sided tape and not pin type that wil leave holes...
Old Oct 26, 2005 | 12:10 PM
BEETROOT's Avatar
Yeehaw
Warm up badges with hair dryer. Slide fishing line or dental floss behind the badges, slowly work the line through the glue until you cut through it and the badge falls off. Follow up with goo gone or rubbing alcohol to get the gunk leftover. Put on a few new coats of wax.
Originally Posted by gsclifton
Brings up 'no matches' for me
Old Oct 26, 2005 | 12:31 PM
JoganJani's Avatar
never stops!
Originally Posted by anthracite06TLNAV
Hello ALL:
I did that exactly. I shaved my badges with dental floss and used goo-gone (is paint safe) to clean the remaining glue. Keep lots of cotton towel handy. While removing the glue if you use the same towel to rub you'll put micro scratches. Clean with Goo-gone and wipe dry DO NOT RUB.
Old Oct 26, 2005 | 10:02 PM
use floss and goo gone
Old Oct 27, 2005 | 12:04 AM
LacViet's Avatar
291hp & 245 tq @ 3.5psi
Check this link for step by step debadging
https://acurazine.com/forums/showthread.php?t=122040
Old Oct 31, 2005 | 11:55 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
and a heat gun. Heat the adhesive up, with heat gun or hair dryer, then use fishing line or dental floss. Then goo gone to get the rest of the tape off, wash, wax (and buff) and no more shadows.
TLDude876
Dec 28, 2016 03:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
HOWELLiNC
3G TL Photograph Gallery
Sep 17, 2015 10:04 PM
buhhbuhh
Jul 27, 2007 09:58 AM
