This combo work pretty good removing road tar on paint
Old Apr 2, 2018 | 07:13 PM
VictorTL's Avatar
I used this combo to remove road tar and tiny sticky stuff on car paint after I clean the car. Not sure if WD40 is safe for car paint.
Old Apr 2, 2018 | 11:24 PM
truonghthe's Avatar
a quick detail spray or good car wash soap can do the job just fine.
Old Apr 3, 2018 | 07:00 AM
VictorTL's Avatar
Mine was so gummed up and soaps doesn’t do it
Old Apr 3, 2018 | 07:25 AM
Levon05TL's Avatar
How are you not sure if it’s safe? I wouldn’t use it then. The purpose of WD40 is to act as a lubricant for the clay bar. Well a quick detailer is a lubricant. Now if you can prove WD40 is better and safer then I’d start using it.
Old Apr 3, 2018 | 12:49 PM
Superunknown's Avatar
WD-40 should not be used as a lubricant.
Did you try a quick detailer first?
Old Apr 3, 2018 | 01:02 PM
Jackass's Avatar
Right or wrong...using WD-40 to help remove tar residue from a car is nothing new. I have no idea if it really is safe, good, or bad...I just know people have been doing that for years.
Old Apr 3, 2018 | 02:24 PM
pohljm's Avatar
wd-40 is the opposite of a lubricant
Old Apr 4, 2018 | 12:36 PM
90foxnotch's Avatar
People cringe when I tell them I've used kerosene or gasoline to in order to get road tar off but when I worked at dealerships this is what we did. One of my boss's even used paint thinner on interiors to remove stains. Soap WILL NOT help you with road tar and a lot of times neither will a clay bar. I always make sure I wax the area after to seal it.
Old Apr 4, 2018 | 01:10 PM
lowered2000tl's Avatar
WD-40 is fine to use on paint. Repainted surfaces I’m not sure but factory paint is fine. I use paint thinner all the time to remove contamination from paint, again, factory paint that is. As long as you wax or polish that area after it’s not a big deal at all.
Old Apr 4, 2018 | 01:17 PM
90foxnotch's Avatar
^Agreed
Old Apr 9, 2018 | 01:13 AM
WDPanda's Avatar
Rubbing alcohol works wonders
JLTSX07
Wash & Wax
Oct 18, 2009 07:02 PM
sinfulj32
2G CL Photograph Gallery
19
Jul 16, 2007 06:49 PM
2001CL
Oct 29, 2003 05:53 AM
6speedS
Wash & Wax
May 17, 2003 02:00 PM
bebber
Sep 4, 2001 01:36 AM
