Clay Baring
Bonki' Ehrite!
Clay Baring
Hi, I have a few questions about claying a car.
-How many bars should I pick up to do a 2g TL?
-Approx. how long will it take to complete?
-Do you wipe the excess lubricant and clay off the paint surface when you are done, or do you let it dry on there?
-Is there different types of clay bars for different finishes?
1 should be ample, even an 80 gm bar is enough for one car. The one I sell is a 180 gm bar.
Depends on how bad it is. I can usually do an entire sedan in about 20 minutes or so.....
Hopefully there's no clay remnants remaining. If there is, something is wrong....Only spray and clay enough area that you can wipe dry when completed.
Different finishes, no. Different conditions, yes. Most surfaces, unless exposed to lots of rail dust, factory fallout or coastal exposure are fine with a light grade bar.
Bonki' Ehrite!
Thanks!
I live a few miles from the beach in S. Florida. Which grade would you recommend?
I know nothing of your current care regimen, or the cars history. I wouldnt hesitate to go with the fine grade though. That will normally get you to a satisfactory level, and establish a base of comparison.
As far a lubicant for the claying process, should I mix up ONR in a spray bottle or can I just use a Meguiars quick detailer (http://www.autogeek.net/meguiars-ult...-detailer.html)
Also, it was more economical.
Im not a huge fan of ONR as a clay lube. Matter of fact theres a member here who called me yesterday who was having issues with the clay, while using NRWS. The edges were falling apart on him. Im not certain if it was the clay, or the fact he was using NRWS as a lube.I really prefer something a little less "chemically". I always use a quick detailer.......
Patrick I'm with you on this one .. what I find is that even with lots of ONR on the surface the clay will stick at the end of a stroke increasing the chances of pulling it out of your hand and I also feel that it doesn't pull off the contaminats as well..
I just buy the Megs QD direct from them by the gallon.
That's why I like the Griot's clay. It comes in a plastic jar with a lid; a quick spritz of Speed Shine right before you seal the jar back up and it's still moist next time I need it.
I used mother clay bar. 1 bar did 5 cars. I heard they come in 2 bar pack now. So 10 cars? I did my accord, friend accord, mom mdx, dad es350, and friend civic si.
I easily used one clay bar on my CL alone.
Granted that was the first time I clayed the car myself...I have no knowledge of it's history before me.
I throw mine in a ziplock, I haven't had any issues drying out. I did my TL and a Durango with the Mother's CG kit with one bar, I think I'll retire that one after two cars.
I tried ONR as a lube today and felt like I was using a ton. Perhaps I'll try a different ratio than they suggest next time.
My car was pretty bad...It was completely black by the time I felt satisfied.
And I wish that would have been only half a bar...but that was the whole thing.
I broke it up in half but the first bar was too filthy so I had to go to the 2nd half.
The 2nd time claying (I think it was Ricardo Clay...?) was much better and I didn't have to use as much.
Bonki' Ehrite!
The 2nd time claying (I think it was Ricardo Clay...?) was much better and I didn't have to use as much.[/quote]
That could be because your car was clean after the first go round.
The guy from the detailing supply shop told me that for my TL, 1/3 of the bar is usually enough to do the entire vehicle. I got the 200g meguiars mild clay, so about 70g is enough to do the car.
Anyone wanna confirm this or will I use too much? I doubt that the car has been clayed ever, so this would be the first time. The paint itself doesn't feel like it's in bad shape but I can feel the roughness in the paint after a wash.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
rboller
09-23-2015 02:49 PM
