Buffers
Buffers
b
I have a question and you guys always have informative answers. So here oges. I was under the impression that buffers were not very good to use. I thought that they left Swirl Marks. I always done all of my Detailing by hand. If a Buffer is good which one is because I would sure like a tool to make waxing on and off easier. I thought that I was a decent detailer until I met you guys. I have a whole lot of products coming and want to make sure that I get optimum results.
Thanks in Advance,
Six Speed
Thanks in Advance,
Six Speed
Driver/Detailer
Don't buy a buffer just to apply wax. It's not worth paying money just for that. I'd recommend you to get a buffer if you wanted to remove swirls. Swirl removal by hand is very tiring and time consuming and you won't come close to the results of a machine. When buffing off your dried wax, use a microfibre cloth by hand or a microfibre bonnet over a stiff foam pad on the buffer.
A random orbital buffer, such as the ones made by Porter Cable willl not produce swirl marks. Even a complete novice, like me, who is "mechanically-challenged" had no problem in using a PC 7336 (I think that's the model number) to remove swirl marks quite effectively.
A PC with the right supplies (pads, polishers, etc) for the job will work wonders. I also used it to apply sealant. It works great.
The PC 7336 can be had at Lowes for $109.
Do a search here on "Porter Cable" and you should find lots of good info on where to get a PC online (along with supplies) and also on how to use it.
The model number is PC 7336 for the model with the 6" counterweight, and 7424 for the model with the 5" counterweight. Either will serve you well. Lowes has the 7336 - I do all my work with it (you can see it at my homepage).
why does a Porter Cable dont produce swirl marks compared to cheaper buffers??? I thought it depends on the pads. Im thing of just purchasing a cheap buffer for the swirl remover and cant justify paying 100$ for a PC yet since im a newb at detailing.
Former Sponsor
I am officially addicted.
The PC as referred to use orbital and concentric motion. Sort of random circles within circles...It can cause swirls, but this is usually at the users discretion. Sometimes you need to remove heavier swirls, with lighter swirls, then step your pad/product combo down, until you have removed the lighter phase swirls. This is normal protocol when removing severely neglected paint. Liken it to sanding down some rough textured wood. You use a course sandpaper, then downscale until its nice and smooth......
The problem with the Craftsmen models is they're not capable of doing this. Nor are there many product options beyond wax removal or light polishing
www.coastaltool.com has the 7424 withthe velcro backing plate and the proper counter weight for $119. ..
My web page also has a link in the drop downs to using the PC .
Oakes
Wash & Wax
10-12-2015 11:17 AM
