Buffer pads - any basic instructionals?
Old Jun 10, 2009 | 10:18 AM
TSXinSouthBayCalifornia's Avatar
As far as I can tell, there is no UNIFORM color code to the buffer pads.
One mild pad might be black, and another abrasive pad might be black.
First off, am I right on this?
Assuming that I am, I wanted to ask what kind of basic buffer pads are there, and if anyone might have an article or post, they might refer me to for the info?
thank you
Old Jun 10, 2009 | 10:29 AM
n0rm's Avatar
I ♡ PEK PEK
http://www.auto-geek.net/lakecountrycomparisonchart.htm
Old Jun 10, 2009 | 11:22 AM
So is there a real standard for the color scheme?
Is Red usually a soft finishing pad, White usually a polishing pad, and Purple usually the most abrasive?
Old Jun 10, 2009 | 11:29 AM
civicdrivr's Avatar
Id love to know if theres a standard as well.
Old Jun 10, 2009 | 12:21 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Most places like excel and detailed image carry pads that all are color coded the same
Old Jun 10, 2009 | 12:52 PM
vinnier6's Avatar
i would say the lake country is the standard color....for a new car you really dont need anything other then a white and gray pad....same as exceldetails colors....red is good too, but i think its too soft for anything other then applying wax or sealants...and i use gray for that....
Old Jun 11, 2009 | 03:48 AM
TOGWT's Avatar
The Old Grey Whistle Test
There is no standardization for the colours used to identify the abrasiveness of foam pads; as a consequence manufacturers adopt their own system of colours, which can lead to confusion
Autogeeks (AG) Green foam is very different from Lake County (LC) Green foam although it’s made and re-labelled by Lake County Manufacturing (LC)
Old Jun 11, 2009 | 07:38 AM
CocheseUGA's Avatar
This is very good info. Looks like I'll stick to one company when I start doing it.
Old Jun 11, 2009 | 09:15 AM
Jesstzn's Avatar
This might help a bit
There are several pad manufacturers, but I will deal expressely with Lake Country Mfg. Now, I could sit here and explain PPI (pores per inch), density, and thickness and widths, but I’m not. Decide what level of aggression you
need, then figure out what size you want to work with. Here it is in simple, laymen terms:
Yellow = Aggressive, use for serious defects, scratches, and swirls. Normally requires follow up with a lighter pad and polish.
Orange = Semi Aggressive, use for light to moderate defects, scratches and swirls. May require follow up with lighter pad and polish combinations. One of the most versatile pads made, can be used after yellow pads for
marring removal, and can also be used for finish polishing on light colored vehicles.
White = Least aggressiveness, use for light defects, scratches and swirls. Normally doesn't require follow up with a lighter pad and polish. Can be used with a wide variety of polishes for differing situations and circumstances. May
be used after Yellow and Orange pads for additional marring removal, or used as a final stage with a light polish.
Black = Non aggressive, use with glazes, all in one products, and sealants on light colored vehicles. Larger pores than Red.
Red = Sealants only
ITSJESTER
17
Dec 6, 2018 02:29 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
thegipper
Sep 28, 2015 01:01 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
