brown stains on inside of wheels
Old 03-11-2008, 10:15 PM
WSZsr's Avatar
My brand new TSX has brown stains on the inside of the wheels. I think it is the protectant they spray on at the factory.
What can I use to remove it?
Thx
Old 03-12-2008, 06:16 AM
Macruz19's Avatar
Try soap and water and wipe off with a MF towel. If that doesn't work use a polish by hand, and it should come right off.
Old 03-12-2008, 07:12 AM
Former Sponsor
exceldetail's Avatar
Could be break in brake pad dust......."should" come off with some wheel cleaner. Get some protection (polymer) on them asap.
Old 03-13-2008, 05:50 AM
WSZsr's Avatar
removed all four tires/wheels and the stains came right off with soap and water. Waxed the inside and reinstalled. Noticed the Acura wheels are made by Enkei.
Old 03-13-2008, 06:10 AM
Macruz19's Avatar
You can do lots with soap and water huh?
Old 03-14-2008, 09:14 PM
tl2go's Avatar
What do you all use when removing the tires and wheels? Do you do one at a time or put the car up on jack stands?
Old 03-14-2008, 10:29 PM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
All I have is a basic floor jack, so I just do one wheel at a time. Or, remove one wheel, replace with spare, and then remove another wheel so I can do two at a time.
Old 03-15-2008, 05:34 AM
WSZsr's Avatar
I used a floor jack and removed one at a time. Just left it jacked up while I washed and cleaned each tire/wheel.
Old 03-15-2008, 10:01 AM
Trucki!!
lembowski's Avatar
I clean the inside when i rotate my wheels. I can spray them out good enough for those 3k miles
02-25-2020 09:57 AM
james357
02-13-2016 02:37 PM
jblessing
Wash & Wax
09-17-2015 09:28 PM
PortlandRL
09-14-2015 12:01 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: brown stains on inside of wheels
