An Affordable Buffer?
What your going to need
1) PC & backing plate
2) 2 Orange pads
3) 3 white pads
4) Optimum Hyper Spray Compound <<--- will do the same as comound & polish depending on the pad its used with
5) Optimum polish
6) Rubbing Alcohol / water 50/50 mix for a wipedown after polishing.
7) Sealant of choise. Layers to be applied at least 24 hours apart.
8) MF towels.
Note .. dump your rubbing compound and the Ice clay bar if its the liquid dump it too. No need to dawn wash twice.
2) 2 Orange pads
3) 3 white pads
5) Optimum polish
8) MF towels.
^why? all the good detailers use a mix of alcohol.
after you polish your ride, you'll have "polish dust" every where. also the polish fills in scratches and swirls. by using the alcohol mix you're revealing your paints true colors...meaning you can see what areas you need to work on more because the mix wipes away the "fillers" in the scratches and swirls.
Chapter Leader (San Antonio)
Well thanks everyone for the help, just purchased the PC Cable with pads with the Prima Care kit. Will make a before-after detailing thread once I get it and do the detail! Again, thanks for all the help!!
Yeah that is what I thought. I was using it like I've read and watched. Put polish on pad, spread it around with machine OFF, then spread it around at speed 3 and than up to speed 5/6 with 15 LB of pressure. Returning it to Detailer Domain to get it checked by Porter Cable.
I did after use the machine for polishing the car (machine OFF- as an applicator) with the Prima Car care and it took off majority of the scratches so I'm happy with the results without actually using the machine.
It removed the scratches. Don't know if there is a difference between filling and removing them, but most of them are gone. I'll get before/after pictures sometime tonight.
Yeah that it was Detailer Domain told me, he's never heard of this happened. I tried googling it the day of the detail with no results leading me to think I'm the first one.
4drviper
Apr 23, 2025 07:13 PM
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
