Timing belt kit from Amazon
Old May 18, 2013 | 11:52 AM
jsmack27's Avatar
Is this the kit to use?
Timing Belt Kit Acura TL V6 2004 to 2007 : Amazon.com : Automotive Timing Belt Kit Acura TL V6 2004 to 2007 : Amazon.com : Automotive
The honda dealer is going to charge me 550 to do the timing belt and water pump. But if I buy the kit and take it to my local mechanic It would probably be a little cheaper.
Old May 18, 2013 | 12:23 PM
Undying Dreams's Avatar
Interested! I love Amazon.
Old May 18, 2013 | 12:36 PM
rossv1's Avatar
I'm interested in this too. I've got about 15K before I need to get mine done.
Edit: Just realized I've put 35K miles on my car in a little under a year.
Old May 20, 2013 | 09:28 AM
madpoz's Avatar
With all due respect to the OP, there are several options other than the link posted which will be lower cost.
Gates kit which several users have installed:
http://www.amazon.com/Gates-TCKWP329-Engine-Timing-Water/dp/B001NYE26U/ref=sr_1_2?s=automotive&ie=UTF8&qid=1369059868&sr=1-2&keywords=timing+belt+kit http://www.amazon.com/Gates-TCKWP329-Engine-Timing-Water/dp/B001NYE26U/ref=sr_1_2?s=automotive&ie=UTF8&qid=1369059868&sr=1-2&keywords=timing+belt+kit
Or this kit by AISIN, which is has parts that are all made by the same manufacturers as OEM. It's out of stock from Amazon at the moment, but I bought this for $160.
http://www.amazon.com/Aisin-TKH-002-Engine-Timing-Water/dp/B008EEYTRE/ref=au_pf_ss_1?ie=UTF8&Make=Acura|58&Model=TL|749&Year=2004|2004&carId=002&n=15684181&s=automotive http://www.amazon.com/Aisin-TKH-002-Engine-Timing-Water/dp/B008EEYTRE/ref=au_pf_ss_1?ie=UTF8&Make=Acura|58&Model=TL|749&Year=2004|2004&carId=002&n=15684181&s=automotive
Old May 20, 2013 | 10:30 AM
TheLowLife's Avatar
Old May 22, 2013 | 09:55 AM
antlive's Avatar
Cruiser
Might have to look into these kits...OEM parts from hondaacuraonline.com 100k service is looking to be $500 (water pump, timing belt, spark plugs, gaskets)
Old May 22, 2013 | 11:02 AM
Comptechtl2367's Avatar
I was just pricing the same thing. Ill be really thinking about buying one of these 200-2500 kits. As long as the bearings are Koyo they are the same as OEM! Its the water pump and tensioner I question.
Old May 22, 2013 | 12:21 PM
nfnsquared's Avatar
Tons of threads on this. The Gates kit is all OEM except for the water pump. I have 30K miles on the Gates kit with no issues.
OP, $550 is not a bad price at all for parts + labor, including water pump and tensioner...
Old May 23, 2013 | 08:18 AM
550 was parts only, no labor. +1 on gates. Ill get the belt and pulley kit and just buy an OEM water pump.
Old May 24, 2013 | 10:08 AM
avoided's Avatar
5th Gear
I oem water pump necessary?
Old May 24, 2013 | 10:36 AM
Its not necessary but I have done over 30+ timing belts over the years and have had 2-4 aftermarket pumps fail... and 0 OEM.
Old May 24, 2013 | 03:07 PM
jsmack27's Avatar
Well I went to the honda dealer for my "$550" timing belt and water pump job with my coupon. Let me clarify. I had a coupon for $499 water pump and timing belt. But on the phone the guy said the water pump was a little extra. It ended up being $99 extra. So it just jumped up to $599. I dropped off the car anyway but added on a transmission fluid change also. Two hours later I get a phone call saying my tensioner was on its last leg and if it breaks blah blah blah.. Okay fix it, thanks. The guy replies well while we are here might as well replace your ac belts it only $8. Okay do that too. An hour later they call me again.. your engine mounts are all broken.. you want us to replace them? I say how much, they want $1300...lol no thats okay.." oh well you car is done other wise. I go pick it up and boom, the bill was $919!!! I like " Ummm excuse me how the hell did a tensioner and $8 ac belts take it to $919.. well the belts is $8, but the labor is $40..The tensioner was $127 but the labor was $80.. WHAT!! they bent me over big time.. but on the good side Im good on the timing belt, tensioner, ac belt, water pump, tranny fluid is red with no metals or grit, and a free car wash lol
Old May 28, 2013 | 07:39 AM
Thats how it works, you get in the door for 599 and then they find another 500 while they are in there. Classic dealership.
Old May 28, 2013 | 10:59 AM
DMZ's Avatar
DMZ
Head a da Family
I'd still go for the AISIN kit from rockauto. All OEM parts without the Honda name on them:
https://www.rockauto.com/catalog/mor...456&cc=1429130
$193.79 + shipping.
Old May 28, 2013 | 11:07 AM
DMZ's Avatar
DMZ
Head a da Family
Not at Hamilton Honda in NJ. They told me up front to replace the hydraulic tensioner because they said almost all are found to be leaking by the time you get to do the Timing belt job. In my case at least, they turned out to be right. The whole job was just under $500 OUT THE DOOR including parts, labor, and tax.
Old May 28, 2013 | 11:19 AM
madpoz's Avatar
I'm sure this will come as no surprise, but the replacing the tensioner is literally 2 or 3 bolts once you're in there. The AC belt has to come off and be put back on whether it gets replaced or not, so the $120 in labor is essentially pure profit.
The practice of quoting a repair cost without giving labor charges really pisses me off. Obviously they don't quote them because they are ripping people off.
Old May 28, 2013 | 11:22 AM
madpoz's Avatar
$193.79 + shipping.
I installed the AISIN kit this weekend...it is indeed identical to the OEM parts, same manufacturer and everything. Paid $160 shipped from amazon!
Old May 28, 2013 | 05:12 PM
MacKenzie001's Avatar
So if I plan on keeping my car for probably 5 years, can someone tell me all the parts one should plan on replacing? I heard whats in the kits plus crank and cam shaft seals? Anything else?
Much appreciated
Old May 29, 2013 | 10:12 AM
madpoz's Avatar
Much appreciated
I didn't do the valve seals since they weren't leaking...now that i've done the timing belt I'm confident I can go back in there to change the seals if they leak in the future. Others do recommend it though...
Here's what I replaced last weekend:
AISIN timing belt kit (TB, water pump, tensioner, idler)
OEM spark plugs
Thermostat
OEM or Goodyear Gator AC drive belt
Gates AC belt tensioner and pulley (i had some noise from the old tensioner and it's easy to replace once you have the car apart for the TB job.)
Also if you haven't done it recently I'd suggest replacing/inspecting:
Power steering fluid
Transmission fluid
Engine oil and filter
Brake fluid
Air filter
Cabin filter
Rotate tires
I also replaced the seals in my power steering pump and changed the transmission filter (only possible on '04 - '06)
I figure I'm good for a while now...maybe I'll try doing a valve adjustment next year if I feel ambitious.
Old May 29, 2013 | 01:17 PM
DMZ's Avatar
DMZ
Head a da Family
Just checked. Amazon's price is $155.64 shipped. Sounds like a deal to me! I bet if you called rockauto and asked them to match that price they just might.
Old May 29, 2013 | 03:34 PM
stvtec's Avatar
'06 WDP TL 6MT
Just ordered the Amazon Aisin kit myself.
Old May 29, 2013 | 05:39 PM
quanaman's Avatar
TL-S
Rock auto has the gates kit got 143$ plus shipping.
Old May 30, 2013 | 09:50 AM
madpoz's Avatar
Don't forget the 5% off code for Rock Auto. Use google to find the latest.
Old May 30, 2013 | 09:18 PM
snake212's Avatar
Man I was lucky I grabbed the last Aisin Kit from amazon Today. $155.64 Man I love Amazon.
Amazon.com: Aisin TKH-002 Engine Timing Belt Kit with Water Pump: Automotive Amazon.com: Aisin TKH-002 Engine Timing Belt Kit with Water Pump: Automotive
Old Jul 2, 2013 | 10:05 AM
For some reason this kit is really cheap now.
Amazon says it went down 43% in price since I added it to my Wish List (when this thread was created).
Old Jul 5, 2013 | 07:47 PM
Hawaii-808's Avatar
7th Gear
Does anyone have a step by step process of the timing belt change with pictures?
Old Jul 5, 2013 | 09:22 PM
abracing's Avatar
https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
Old Jul 8, 2013 | 01:18 PM
TexanAttorney's Avatar
What other parts do I need after buying the Aisin kit?
Old Jul 11, 2013 | 01:24 PM
Does anyone have part numbers for:
OEM spark plugs
Thermostat
AC drive belt
Crank/Camshaft seals
Old Jul 11, 2013 | 01:31 PM
http://www.acuraoemparts.com/delray/jsp/catdisplay.jsp
You can get any OEM part number your heart desires!
Old Jul 12, 2013 | 11:54 AM
94eg!'s Avatar
#1 Super Guy!
$193.79 + shipping.
You are mistaken it is NOT all OEM. Only the tensioner, & pulleys are OEM (and maybe the belt). Honda water pumps are made by Yamada, not Aisin.
http://www.oemacuraparts.com/oem-par.../19200-rdv-j01
OEM ACURA WATER PUMP (YAMADA) for 2005 ACURA TL | Part number 19200-RDV-J01
Also, almost all Honda timing belts are made by Unitta. Espeically the high performance ones. Unitta is just the name Gates uses for it's Asian market.
Old Jul 16, 2013 | 12:24 AM
pnokio's Avatar
On Aisin kits, tb brand is mitsubishi... Is this oem? I read that Gates/Unitta is oem ... Why people keep buying Aisin kits instead of Gates kits? Gates kits oem on everything except Water Pump.
Is this a good option
Buying Aisin kit plus only gates timing belt on Rockauto... So, you'll have oem tb, tensionner, etc. And I read here that Aisin water pump was oem on the earlier built TL so it will make all oem?
My dilemma is wich one is better?
Old Jul 16, 2013 | 10:20 AM
madpoz's Avatar
Just my 2 cents, while I appreciate and share your desire to get the best possible parts at the lowest possible price, I can tell you either kit will be fine. There are members here using gates without issue...I'm using the Aisin kit without issue. Honda/Acura uses several OEM manufacturers so you can and will drive yourself crazy trying to match everything up.
When I took the parts off my 2004 TL, the brand and stamping of every part in the Aisin kit except the TB itself were identical to the OEM. The TB was high quality and I have no doubt it's every bit as good as the OEM belt.
Try not to over-think the parts list...just think about how much money you're saving instead!
Old Jul 17, 2013 | 09:18 AM
IntactACK's Avatar
I've been running the aisin kit for quite some time, no issues at all
Old Jul 17, 2013 | 11:35 AM
pnokio's Avatar
Thank you guys
Old Aug 7, 2013 | 01:44 PM
antlive's Avatar
Cruiser
might be order the aisin kit today....
Old Aug 7, 2013 | 11:00 PM
MyBabysBaby's Avatar
From the Amazon site, "Original equipment matched idler and tensioner bearings"
Does that mean the TB tensioner, hydraulic tensioner and idler pulley?
Old Aug 8, 2013 | 06:18 AM
IntactACK's Avatar
Not positive...All parts looked OEM to me. I installed myself with bisimoto stage two cams and beat the shit out of my car and so far have had no issues...that doesn't mean much though lol
Old Aug 8, 2013 | 03:34 PM
94eg!'s Avatar
#1 Super Guy!
Yes, both the Aisin kit and the Gates kit have identical parts. The only difference between the two are the timing belts and water pumps.
Old Aug 9, 2013 | 10:22 PM
Just bought the Gates kit.
Also bought NGK plugs for $52.05 w/ shipping from Advance.
$10 off $30 Code A124
$20 off $50 Code ES123
$30 off $80 Code RAF51112
$50 off $125 Code DOW32
Free shipping on orders over $75
